Visitor wsmich
Getting started with reVISION - needed equipment
Hi everyone,
i want to get started with the reVISION stack. For that i have a questions that can maybe be answered of someone.
Do you need one of the suggested cameras for the Dense Optical Flow example or can you use another usb-camera?
"Live I/O: Dense Optical Flow - requires LI-IMX274MIPI-FMC or HDMI source or See3CAM_CU30 USB camera"
Any information and help is very appreciated.
Best regards
Re: Getting started with reVISION - needed equipment
The user components mentioned in the wiki article here:http://www.wiki.xilinx.com/reVISION+Getting+Started+Guide
have been tested to work successfully with the reference design. Alternative components might work but Xilinx any other components with its reference design.
Please mark an answer "Accept as solution" if a post has the solution to your issue.
Newbie xilinxeng
@akshayva I have questions about the reVISION tools.  Do you have contact info for someone that can answer questions about the reVISION software?  I know I can post questions on this forum.  But I don't think that's appropriate since I really need some guidance on the product.  I've looked at the reVISION getting started guide and other online resources.
Visitor vandenplas
Did you get the revision stack to work?
I just get a message saying
  I get the following error No M_AXI_GP port found in the platform!
Help!
