Visitor victor1969
HLS IP direct connection to a C-callable IP
I'm using a C-callable IP. It's a LDPC decoder previously design at RTL level and packaged with sdx_pack
This is the declaration:
#pragma SDS data access_pattern(y_rx:SEQUENTIAL,c_final:SEQUENTIAL)
void NMS_decoder_AXI_STREAM(int y_rx[128], int c_final[128]);
where y_rx is mapped to an AXI_STREAM input and c_final to an AXI_STREAM output
I call the NMS_decoder_AXI_STREAM function in my main code and SDSOC is making synthesis correctly. Checked on a ZCU102 board.
The y_rx input is generated from a c function. Now, I order the SDSOC tool to make that function in hardware. It uses HLS to make that task. The problem is that it is not making a direct HW connection between both HW modules. It is passing y_rx value through memory (via DMAs).
How can I force a direct connection?
