How to force 64 bits wide AXI connections on SDSoC?
I have a function which will be executed in the PL which reads 6 floats and returns 6 floats. The width of the AXI connections (either ACP or HP) are obviously implemented using 32-bits.
Is there any way of making those connections 64 bits wide?
I have tried using long long pointers and then converting the pointer to float inside the IP but I get this error:
unsupported pointer reinterpretation from type 'i64*' to type 'float*' on variable 'inaddr'
Cerilet
Teacher muzaffer
Re: How to force 64 bits wide AXI connections on SDSoC?
@cerilet have you tried
top(unsigned long long * memory, ...) {
unsigned long long local[3];
memcpy(local, memory, 24);
float fl[6];
fl[0] = *static_cast<float*>(local);
fl[1] = *(static_cast<float*>(local)+1);
I think you can also give a try to structure datatype to match 64bit wide data:
typedef struct {
      float data[2];
} float2;
void func_decl (float2* in, float2* out){
   for (int i = 0 ; i < size_of_input_data ; i++)
          float2 input = in[i];
          float first = input.data[0];
          float second = input.data[1];
Hi @muzaffer and @heeran,
None of those options worked.
@muzaffer's solution gives this error:
Pragma processor failed: ddr_test.cpp:19:11: error: static_cast from 'unsigned long long *' to 'float *' is not allowed
        in[0] = *static_cast<float*>(local);
Whilst @heeran's solution implements a 32-bit wide bus.
I have tried also simple cast in @muzaffer's option, but it doesn't work either. Even playing a bit with casting, the C compilation might work, but when I try the synthesis I get these errors:
ERROR: [SYNCHK 200-22] ddr_test.cpp:17: memory copy is not supported unless used on bus interface possible cause(s): non-static/non-constant local array with initialization).
ERROR: [SYNCHK 200-41] ddr_test.cpp:6: in function 'ddr_test': unsupported pointer reinterpretation from type '[3 x i64]*' to type 'i32' on variable 'local'.
It must be a way of implementing this.
I tried structure datatype (containing two floats) and was can see kernel DATAWIDTH to 64 bit wide.
please refer attached source code "array_zero_copy.cpp" file. Its a zero copy example (no DMA). Kernel is directly connected to ACP interface of PS7 IP. This example is tested with 2016.3 SDx tool.
