How to generate 32-bit address ports in SDSoC (SDx)
Hi all,
I am using SDx GUI toolset. (SDSoC)
And the ZCU102 – zynq MPSoC evaluation board.
The SDx tool in my case generates a 64-bit address ports when I use m_axi interface.
I have seen in UG1253 on page 78 that
“m_axi: Implements all ports as an AXI4 interface. You can use the config_interface command to specify either 32-bit (default) or 64-bit address ports and to control any address offset.”
Could anybody let me know how I can use the config_interface command in SDx GUI to generate 32-bit address ports for my design?
Mohammad
Re: How to generate 32-bit address ports in SDSoC (SDx)
I found a possible solution for this. Hopefully, it is also useful for others.
in SDx GUI environment
1- create a tcl file containing "config_interface -m_axi_addr64=false"
2- add the top function to the hw modules (by right-click and selecting "Toggle HW/SW")
3- attach the tcl file to the top function hardware by clicking on the function name and then selecting "Vivado HLS-->specify directive TCL file"
