Observer chenhao_7
How to get the CPU time of building an SDSoC project?
Hi all,
I was trying to find the total CPU time taken by building an SDSoC project. However, only the wall clock time was reported in SDSoC log file. I found some CPU time reports in synthesis logs generated by Vivado HLS. I am not sure if simply gathering all such reports will solve my problem.
Is there any way to collect CPU time conveniently?
Thanks!
Re: How to get the CPU time of building an SDSoC project?
Hi @chenhao_7
Kindly explain about the problem you mentioned in post.
What is your goal in finding CPU time.
Best Regards,
Nutan
Teacher xilinxacct
@chenhao_7
If I understand your question.... if you are launching the program from an OD that supports the 'time' command, you could use that... (e.g. time ./myprog ) That will break down the time into user/system/total
