How to link OpenCV library with SDSoC
I am new in SDSoC. I developed an image processing algorithm on my PC. Now I want to port this algorithm on Zybo board.
First of all I want to run the algorithm on ARM without hardware acceleration using Linux system configuration.
When I Build the program in SDSoC I get the following errors:
- Build failed    Hand_gesture_recognition_1             C/C++ Problem
- Exiting sds++ : Error when calling 'arm-linux-gnueabihf-g++
- undefined reference to `cv::_InputArray::_InputArray(cv::Mat const&)'
- undefined reference to `cv::_OutputArray::_OutputArray(cv::Mat&)'
- undefined reference to `cv::cvtColor(cv::_InputArray const&, cv::_OutputArray const&, int, int)'
- undefined reference to `cv::fastFree(void*)'
- undefined reference to `cv::line(cv::Mat&, cv::Point_<int>, cv::Point_<int>, cv::Scalar_<double> const&, int, int, int)'
- undefined reference to `cv::Mat::copySize(cv::Mat const&)'
- undefined reference to `cv::Mat::copyTo(cv::_OutputArray const&) const'
- undefined reference to `cv::Mat::create(int, int const*, int)'
- undefined reference to `cv::Mat::deallocate()'
- undefined reference to `cv::split(cv::Mat const&, std::vector<cv::Mat, std::allocator<cv::Mat> >&)'
I don't know exactly how to link OpenCV library with SDSoC. Could someone guide me in this direction?
Thank you!
Tags (2)
Re: How to link OpenCV library with SDSoC
I resolved the issue in the following way:
1. I downloaded the OpenCV Library Suite for SDSoC from Xilinx SDSoC page: https://www.xilinx.com/products/design-tools/software-zone/sdsoc.html#libraries
2. I followed the steps described in the library's documentation to link the OpenCV Library.
Teacher muzaffer
@bogdan.deac where did you install opencv ? usually it's as easy as -L lopencv_core etc.
I followed the steps from this tutorial: http://www.jonataubert.com/tuto/use_opencv_sdsoc.php steps 3.1) Include path, 3.2) Link the library and 3.3) Add -rpath-link. I use SDSoC 2016.4 on CentOS 7. In ThirdParty folder I don't have the opencv folder. On the other hand I have installed SDK and if I follow this path: /opt/Xilinx/SDK/2016.4/data/embeddedsw/ThirdParty/opencv/aarch32 there are two folders: include and lib. In include folder are another two folders: opencv and opencv2.
I copied the opencv folder from /opt/Xilinx/SDK/2016.4/data/embeddedsw/ThirdParty/ in my Workspace.
In 3.1) Include path step I used /home/bdeac/Workspace/Licenta/SDSoC/opencv/aarch32/include/opencv2.
In 3.2) Link the library step I used /home/bdeac/Workspace/Licenta/SDSoC/opencv/aarch32/lib.
In 3.3) Add -rpath-link step I used -Wl,-rpath-link=/home/bdeac/Workspace/Licenta/SDSoC/opencv/aarch32/lib.
With this configuration I get the mentioned errors.
Visitor cheng_yang
Hi,I want to know what should I do to link sdsoc2017.1 and opencv,I have already download xfopencv library,but I cannot find the link step....Please tell me in detail......thank you so much
Visitor ykpgrr
I am also struggling with to link OpenCV library with SDx platform.
I am currently using the SDx 2017.2 version with ZEDBOARD. I compiled the OpenCV library with cross compile for arm and I follow this steps too:
But I cannot solve this issue. I get this error message when I want to build my code with OpenCV library:
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'arm-linux-gnueabihf-g++     C:/Users/ykpgrr/Desktop/FPGA/workspaceSDx/preprocessing/Release/src/Preprocessing.o C:/Users/ykpgrr/Desktop/FPGA/workspaceSDx/preprocessing/Release/src/main.o C:/Users/ykpgrr/Desktop/FPGA/workspaceSDx/preprocessing/Release/_sds/swstubs/portinfo.o {-LC:\build_hardfp\lib} -lopencv_core -lopencv_imgproc -lopencv_imgcodecs -lopencv_features2d -lopencv_calib3d -lopencv_flann   -L C:/Xilinx/SDx/2017.2/target/aarch32-linux/lib -LC:/Users/ykpgrr/Desktop/FPGA/workspaceSDx/preprocessing/Release/_sds/swstubs -Wl,--start-group  -Wl,--end-group -Wl,--start-group    -lpthread -lsds_lib -lxlnk_stub  -Wl,--end-group -o C:/Users/ykpgrr/Desktop/FPGA/workspaceSDx/preprocessing/Release/_sds/swstubs/preprocessing.elf'
I also added my project's C/C++ Build Settings: (build_hardfp is Opencv Library for arm)
HI ykpgrr,
It looks like this thread already has an accepted solution. Please start another thread if the solution for this one doesn't work for you.
Sam
Visitor semchan
hello, I also meet the same issue,may I know how you fixed the issue? Thanks a lot.
Visitor semchan
hi, skalicky,
could you please explain the actions in detail? thanks.
Visitor ykpgrr
Opencv library should be cross compiled with arm-linux-gnueabihf for developing Linux applications. Please look at page 12: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug1027-sdsoc-user-guide.pdf
Observer xiangzhi
Hi,I'm using SDSoC 2017.4.I meet this problem.
"D:\Xilinx\SDx\opencv-2.4.10-ARMlib\lib/libopencv_core.so: file not recognized: File format not recognized"
Why?The libs files that I'm using is the libs of zcu102-rv-ss-2017-4.
Participant hitpmpm@163.com
hello @bogdan.deac
I met the same problem,can you tell me more details,which pdf did you use,thanks very much!
I have just installed SDx 2017.4. I will come back with a response in the following days.
Best regards,
Bogdan D.
I use SDSoC 2018.2 on Ubuntu-16.04.2-desktop-amd64, want to get video from USB and send it to the DP display, for the next step of video processing, neural network and hardware acceleration.
I make a new project based on zcu104, the source code test.cpp is:
#include <iostream>
#include <cstdio>
#include <stdlib.h>
#include <string.h>
#include <opencv2/opencv.hpp>
using namespace std;
int main()
	cout<<"Test"<<endl;
	cv::VideoCapture cap(1);
	cv::Mat img;
	if (!cap.isOpened())
		cout<<"cannot open the camera "<<endl;
		return -1;
	while (true)
		cap>>img;
		cv::imshow("output",img);
		cv::waitKey(0);
	return 0;
In 3.1) Include path step I used /opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/include/opencv2
In 3.2) Link the library step I used Librarys(-l) with opencv_core, opencv_features2d, opencv_highgui, opencv_imgproc, and search path(-L)with /opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib
In 3.3) Add -rpath-link step I used -Wl,-rpath-link=/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib
In compile step, it reports "cv::VideoCapture cannot be referenced correctly". The specific log information is as follows:
11:32:50 **** Incremental Build of configuration Release for project test ****
make pre-build main-build
sdsoc_make_clean Release
Building file: ../src/test.cpp
Invoking: SDS++ Compiler
sds++ -Wall -O3 -I"../src" -I/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/include/opencv2 -c -fmessage-length=0 -MT"src/test.o" -MMD -MP -MF"src/test.d" -MT"src/test.o" -o "src/test.o" "../src/test.cpp" -sds-sys-config a53_linux -sds-proc a53_linux -sds-pf "zcu104"
Create data motion intermediate representation
/opt/pkg/Xilinx/Vivado/2018.2/include/opencv2/ml/ml.hpp:957:18: warning: 'CvForestTree::train' hides overloaded virtual functions [-Woverloaded-virtual]
    virtual bool train( CvDTreeTrainData* trainData, const CvMat* _subsample_idx, CvRTrees* forest );
/opt/pkg/Xilinx/Vivado/2018.2/include/opencv2/ml/ml.hpp:863:18: note: hidden overloaded virtual function 'CvDTree::train' declared here: different number of parameters (2 vs 3)
    virtual bool train( CvMLData* trainData, CvDTreeParams params=CvDTreeParams() );
/opt/pkg/Xilinx/Vivado/2018.2/include/opencv2/ml/ml.hpp:873:26: note: hidden overloaded virtual function 'CvDTree::train' declared here: different number of parameters (8 vs 3)
    CV_WRAP virtual bool train( const cv::Mat& trainData, int tflag,
/opt/pkg/Xilinx/Vivado/2018.2/include/opencv2/ml/ml.hpp:1145:18: warning: 'CvBoostTree::train' hides overloaded virtual functions [-Woverloaded-virtual]
Compiling /home/user/workspace/test/src/test.cpp
sds++ log file saved as /home/user/workspace/test/Release/_sds/reports/sds_test.log
Finished building: ../src/test.cpp
Building target: test.elf
Invoking: SDS++ Linker
sds++ -L/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib -Wl,-rpath-link=/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib --remote_ip_cache /home/user/workspace/ip_cache -o "test.elf"  ./src/test.o   -lopencv_core -lopencv_features2d -lopencv_highgui -lopencv_imgproc -dmclkid 1  -sds-sys-config a53_linux -sds-proc a53_linux -sds-pf "zcu104"
Removing implementation files from previous run
Analyzing object files
... /home/user/workspace/test/Release/src/test.o
Using prebuilt hardware
Skipping block diagram (BD), address map, port information and device registration for partition 0
Prepare hardware access API functions
Create accelerator stub functions
Compile hardware access API functions
Compile accelerator stub functions
Enable generation of boot files
Link application ELF file
/opt/pkg/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: warning: libgtk-3.so.0, needed by /opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/pkg/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: warning: libgdk-3.so.0, needed by /opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/pkg/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: warning: libcairo.so.2, needed by /opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/pkg/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: warning: libgdk_pixbuf-2.0.so.0, needed by /opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/pkg/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: warning: libgobject-2.0.so.0, needed by /opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/pkg/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: warning: libglib-2.0.so.0, needed by /opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/pkg/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: warning: libjpeg.so.62, needed by /opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1, not found (try using -rpath or -rpath-link)
/opt/pkg/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: warning: libwebp.so.6, needed by /opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1, not found (try using -rpath or -rpath-link)
/opt/pkg/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: warning: libpng16.so.16, needed by /opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1, not found (try using -rpath or -rpath-link)
/opt/pkg/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.2.1/../../../../aarch64-linux-gnu/bin/ld: warning: libtiff.so.5, needed by /opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1, not found (try using -rpath or -rpath-link)
/home/user/workspace/test/Release/src/test.o: In function `main':
test.cpp:(.text.startup+0x78): undefined reference to `cv::VideoCapture::VideoCapture(int)'
test.cpp:(.text.startup+0xac): undefined reference to `cv::VideoCapture::isOpened() const'
test.cpp:(.text.startup+0xd0): undefined reference to `cv::VideoCapture::operator>>(cv::Mat&)'
test.cpp:(.text.startup+0xf8): undefined reference to `cv::_InputArray::_InputArray(cv::Mat const&)'
test.cpp:(.text.startup+0x104): undefined reference to `cv::imshow(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, cv::_InputArray const&)'
test.cpp:(.text.startup+0x14c): undefined reference to `cv::VideoCapture::~VideoCapture()'
test.cpp:(.text.startup+0x180): undefined reference to `cv::VideoCapture::~VideoCapture()'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_filter@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_get_IHDR@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_create_read_struct@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_time_val_add'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_queue_draw'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_simple_progression@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_finish_compress@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_write_scanlines@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_file_chooser_add_filter'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_return_if_fail_warning'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_type_register_static_simple'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_file_filter_add_pattern'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_timeout_add'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFReadRGBATile'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `WebPEncodeBGRA'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gdk_pixbuf_new_from_data'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFSetWarningHandler'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gdk_window_get_height'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_write_image@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `WebPEncodeLosslessBGRA'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_std_error@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_get_parent_window'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFSetField'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `WebPDecodeBGRAInto'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_style_attach'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_get_type'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_window_resize'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_set_quality@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_cond_broadcast'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_finish_decompress@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_type_check_instance_cast'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_usleep'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFClose'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_compression_strategy@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFReadRGBAStrip'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_stdio_src@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_get_window'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFGetField'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_get_current_time'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_type_class_peek'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_gray_to_rgb@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_window_set_geometry_hints'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_get_style'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_queue_resize'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_create_write_struct@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_alloc_huff_table@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_error@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_range_set_range'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_get_io_ptr@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_set_defaults@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_set_window'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_read_scanlines@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_CreateCompress@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gdk_window_new'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_set_allocation'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_range_get_type'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_scale_set_digits'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_file_chooser_set_filter'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_interlace_handling@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_container_get_type'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_window_move'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_write_info@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_palette_to_rgb@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_destroy_read_struct@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFReadEncodedTile'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_read_update_info@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_thread_self'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_get_allocated_width'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFWriteScanline'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_start_compress@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_label_new'
make: *** [test.elf] Error 1
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFReadDirectory'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_cond_new'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFReadEncodedStrip'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_CreateDecompress@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_window_set_title'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_bgr@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_container_add'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_get_allocation'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_box_get_type'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_file_filter_new'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_signal_connect_data'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_vbox_new'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_start_decompress@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_destroy_decompress@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_destroy'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_box_pack_start'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_file_chooser_set_current_name'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFIsTiled'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFWriteEncodedStrip'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_file_chooser_get_type'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_get_visual'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gdk_window_get_width'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_add_events'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_box_pack_end'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_range_set_value'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_thread_create'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_IHDR@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_mutex_lock'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_main_iteration_do'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_window_new'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_thread_yield'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFOpen'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_free'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_destroy_write_struct@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_expand_gray_1_2_4_to_8@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_scale_get_type'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gdk_window_move_resize'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFSetErrorHandler'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_mutex_unlock'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `WebPEncodeBGR'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_file_chooser_get_filename'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_dialog_get_type'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_mutex_new'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_resync_to_restart@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_range_get_value'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_rgb_to_gray@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_longjmp_fn@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_create_info_struct@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_destroy_compress@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_type_check_instance_is_a'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_calc_output_dimensions@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_window_set_resizable'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_dialog_run'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_file_chooser_dialog_new'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `WebPEncodeLosslessBGR'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_get_realized'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_show'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_object_unref'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_strip_16@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFRGBAImageOK'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_window_unfullscreen'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `WebPDecodeBGRInto'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_file_filter_set_name'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFScanlineSize'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_read_header@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `TIFFNumberOfStrips'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gdk_window_set_user_data'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_scale_set_draw_value'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `cairo_paint'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_write_fn@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_window_get_title'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_new'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_file_chooser_set_do_overwrite_confirmation'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_init'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_write_end@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_packing@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_read_info@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_read_image@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_cond_timed_wait'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_hbox_new'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_set_style'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `jpeg_stdio_dest@LIBJPEG_6.2'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_get_allocated_height'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_read_end@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_get_events'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_window_fullscreen'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_type_check_class_cast'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `WebPGetFeaturesInternal'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_read_fn@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_hscale_new_with_range'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_get_tRNS@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_compression_level@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gdk_cairo_set_source_pixbuf'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_swap@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_init_io@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_imgcodecs.so.3.1: undefined reference to `png_set_strip_alpha@PNG16_0'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_widget_set_realized'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_style_set_background'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_cond_wait'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `gtk_window_get_type'
/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib/libopencv_highgui.so: undefined reference to `g_source_remove'
collect2: error: ld returned 1 exit status
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'aarch64-linux-gnu-g++     /home/user/workspace/test/Release/src/test.o /home/user/workspace/test/Release/_sds/swstubs/portinfo.o -L/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib -Wl,-rpath-link=/opt/pkg/Xilinx/SDK/2018.2/data/embeddedsw/ThirdParty/opencv/aarch64/lib -lopencv_core -lopencv_features2d -lopencv_highgui -lopencv_imgproc   -L /opt/pkg/Xilinx/SDx/2018.2/target/aarch64-linux/lib -L/home/user/workspace/test/Release/_sds/swstubs -Wl,--start-group  -Wl,--end-group -Wl,--start-group    -lpthread -lsds_lib -lxlnk_stub  -Wl,--end-group -o /home/user/workspace/test/Release/_sds/swstubs/test.elf'
sds++ log file saved as /home/user/workspace/test/Release/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
makefile:45: recipe for target 'test.elf' failed
11:33:13 Build Finished (took 23s.16ms)
How can I link the OpenCV library and correctly reference cv::VideoCapture?
Observer emilie
Hello @herry,
I am facing the same issue! I know it's been a while but do you remember how you fixed it ?
Emilie
