How to solve axi stream problem ???
This is error message.
Description Resource Path Location Type
Hardware function 'Convolution_Layer_1' appears to have an inconsistent port mapping. The axis_acc_adapter supports at most 8 BRAM or FIFO inputs (bram_in: 53, fifo_in: 0). To address this issue, change HLS fifo/bram interfaces to explicit AXI streams. You must explicitly code AXI stream sideband signals: TLAST, TKEEP, TUSER, and TDEST to comply with SDSCC datamover requirements. Lenet C/C++ Problem
and this is function port mapping
#pragma SDS data copy(src[0:28][0:28])
#pragma SDS data mem_attribute(src:NON_CACHEABLE)
#pragma SDS data copy(convolution_filer[0:20][0:25])
#pragma SDS data mem_attribute(convolution_filer:NON_CACHEABLE)
#pragma SDS data copy(dst[0:20][0:24][0:24])
void Convolution_Layer_1(float src[28][28], float convolution_filer[20][25], float dst[20][24][24]);
i don't know hot to solve this problem. is there any problem of port mapping?
Moving to SDSoC Board.
Debraj
my board is zc706. what is the reason of this problem ?
Hi po092000,
Based on the information you've given, ive created this sample main code:
void Convolution_Layer_1(float src[28][28], float convolution_filer[20][25], float dst[20][24][24]) {
int main() {
	float src[28][28];
	float convolution_filer[20][25];
	float dst[20][24][24];
	Convolution_Layer_1(src,convolution_filer,dst);
	return 0;
However, this code runs through 2016.2 SDSoC without errors. Can you post a more complete source code (or at least representative subset) that shows the problem?
Sam
