Visitor radhikamkr
Integration error while building project in SDSoC
When I was building a project in SDSoC, I am getting the following errors:
make: *** [all] Error 1    frontend_system             C/C++ Problem
make: *** [frontend.elf] Error 1    frontend             C/C++ Problem
recipe for target 'frontend.elf' failed    makefile    /frontend/Release    line 45    C/C++ Problem
SdsCompiler 83-5004: Build failed    frontend             C/C++ Problem
SdsCompiler 83-5019:compiler.deleteDefaultReportConfigs=false" '    frontend        line 0    C/C++ Problem
VPL 60-704: Integration error, problem implementing dynamic region, route_design ERROR    frontend             C/C++ Problem
VPL 60-806: Failed to finish platform linker    frontend             C/C++ Problem
VPL-4: Design failed to meet timing.    frontend             C/C++ Problem
Can anyone please suggest how to resolve these errors?
Re: Integration error while building project in SDSoC
@radhikamkr
Most of these look like they stem from the same root cause... look in frontend and resolve that error, and things will look much better.
Visitor radhikamkr
Can you suggest any possible errors?
The code is running fine in Vivado_HLS. But giving these errors in SDSoC.
Hi @radhikamkr
Looks like the design has got timing violations.
Please add explore directive and give it a try.
sds++ -xp "vivado_prop:run.impl_1.{STEPS.PHYS_OPT_DESIGN.ARGS.MORE OPTIONS}={-directive Explore}" -xp "vivado_prop:run.impl_1.{STEPS.ROUTE_DESIGN.ARGS.MORE OPTIONS}={-directive Explore}"
Refer below screenshot
Best Regards,
Nutan
Visitor radhikamkr
Sorry,But what does this directive do?
Hi @radhikamkr
When there are timing violations in your design, it means that timing requirements were not met for all paths in your design.
If the Vivado router is run with the EXPLORE directive, it can add additional clock roots to a net in order to improve the quality of the results.
Best Regards,
Nutan
Visitor radhikamkr
I tried adding the directive. But of no use.
The functions when hardware accelerated individually, are working fine. The trouble comes when all the functions are called inside a function and the top function is hardware accelerated.
I am attaching my code below.
Can you please look into it if possible.
Hi @radhikamkr
Please send the timing report  *_timing_summary.rpt
Best Regards,
Nutan
Visitor radhikamkr
When I inline the functions the timing error is coming. When I remove it there is no timing error. But resource utilization is going up. Why is this happening?
Sorry, I couldn't locate the timing report.
Hi @radhikamkr
In your project folder based on your build configuration, there will be a Debug or Release Folder, inside it, there should be _sds folder. You can find timing report inside that
Best Regards,
Nutan
