Observer radhikamkr
Integration error while building project in SDSoC
When I was building a project in SDSoC, I am getting the following errors:
make: *** [all] Error 1    frontend_system             C/C++ Problem
make: *** [frontend.elf] Error 1    frontend             C/C++ Problem
recipe for target 'frontend.elf' failed    makefile    /frontend/Release    line 45    C/C++ Problem
SdsCompiler 83-5004: Build failed    frontend             C/C++ Problem
SdsCompiler 83-5019:compiler.deleteDefaultReportConfigs=false" '    frontend        line 0    C/C++ Problem
VPL 60-704: Integration error, problem implementing dynamic region, route_design ERROR    frontend             C/C++ Problem
VPL 60-806: Failed to finish platform linker    frontend             C/C++ Problem
VPL-4: Design failed to meet timing.    frontend             C/C++ Problem
Can anyone please suggest how to resolve these errors?
Re: Integration error while building project in SDSoC
Hi @microlijun
I checked your report, in your design slack is slightly more.
Please try below option and let me know if it helps.
sds++ -xp "vivado_prop:run.impl_1.{STEPS.PLACE_DESIGN.ARGS.MORE OPTIONS}={-fanout_opt}"
Best Regards,
Nutan
Teacher xilinxacct
@radhikamkr
Most of these look like they stem from the same root cause... look in frontend and resolve that error, and things will look much better.
Observer radhikamkr
Can you suggest any possible errors?
The code is running fine in Vivado_HLS. But giving these errors in SDSoC.
Hi @radhikamkr
Looks like the design has got timing violations.
Please add explore directive and give it a try.
sds++ -xp "vivado_prop:run.impl_1.{STEPS.PHYS_OPT_DESIGN.ARGS.MORE OPTIONS}={-directive Explore}" -xp "vivado_prop:run.impl_1.{STEPS.ROUTE_DESIGN.ARGS.MORE OPTIONS}={-directive Explore}"
Refer below screenshot
Best Regards,
Nutan
Observer radhikamkr
Sorry,But what does this directive do?
Hi @radhikamkr
When there are timing violations in your design, it means that timing requirements were not met for all paths in your design.
If the Vivado router is run with the EXPLORE directive, it can add additional clock roots to a net in order to improve the quality of the results.
Best Regards,
Nutan
Observer radhikamkr
I tried adding the directive. But of no use.
The functions when hardware accelerated individually, are working fine. The trouble comes when all the functions are called inside a function and the top function is hardware accelerated.
I am attaching my code below.
Can you please look into it if possible.
Hi @radhikamkr
Please send the timing report  *_timing_summary.rpt
Best Regards,
Nutan
Observer radhikamkr
When I inline the functions the timing error is coming. When I remove it there is no timing error. But resource utilization is going up. Why is this happening?
Sorry, I couldn't locate the timing report.
Hi @radhikamkr
In your project folder based on your build configuration, there will be a Debug or Release Folder, inside it, there should be _sds folder. You can find timing report inside that
Best Regards,
Nutan
Hi @radhikamkr
Is the issue resolved?
I can help you to solve the issue if you provide the timing report.
Best Regards,
Nutan
Observer radhikamkr
Yes the issue was resolved.
I was calling all the functions inside a top function with inline pragma applied to all the functions.
It was causing the timing error.
Visitor microlijun
@nutang
Hi, I was migrating my OpenCV application to xfOpenCV. My design also have timming issue. I got the following error when build with SDx2018.2. How can I fix this? By the way, I did not find any timing_summary.rpt
[20:43:27] Starting logic routing..
[20:43:52] Phase 1 Build RT Design
[20:44:59] Phase 2 Router Initialization
[20:44:59] Phase 2.1 Fix Topology Constraints
[20:44:59] Phase 2.2 Pre Route Cleanup
[20:45:05] Phase 2.3 Global Clock Net Routing
[20:45:17] Phase 2.4 Update Timing
[20:46:49] Phase 2.5 Update Timing for Bus Skew
[20:46:49] Phase 2.5.1 Update Timing
[20:47:13] Phase 3 Initial Routing
[20:48:03] Phase 4 Rip-up And Reroute
[20:48:03] Phase 4.1 Global Iteration 0
[20:53:20] Phase 4.2 Global Iteration 1
[20:55:27] Phase 4.3 Global Iteration 2
[20:56:10] Phase 5 Delay and Skew Optimization
[20:56:10] Phase 5.1 Delay CleanUp
[20:56:10] Phase 5.1.1 Update Timing
[20:56:41] Phase 5.2 Clock Skew Optimization
[20:56:47] Phase 6 Post Hold Fix
[20:56:47] Phase 6.1 Hold Fix Iter
[20:56:47] Phase 6.1.1 Update Timing
[20:57:17] Phase 7 Route finalize
[20:57:17] Phase 8 Verifying routed nets
[20:57:17] Phase 9 Depositing Routes
[20:57:41] Phase 10 Leaf Clock Prog Delay Opt
[20:58:48] Phase 10.1 Delay CleanUp
[20:58:48] Phase 10.1.1 Update Timing
[20:59:49] Phase 10.2 Hold Fix Iter
[20:59:55] Phase 10.2.1 Update Timing
[21:01:21] Phase 11 Depositing Routes
[21:01:39] Phase 12 Post Router Timing
[21:02:22] Phase 13 Physical Synthesis in Router
[21:02:22] Phase 13.1 Physical Synthesis Initialization
[21:03:48] Phase 13.2 Critical Path Optimization
[21:03:54] Phase 14 Route finalize
[21:03:54] Finished 5th of 6 tasks (FPGA routing). Elapsed time: 00h 20m 26s
[16:40:23] Starting bitstream generation..
===>The following messages were generated while Compiling (bitstream) accelerator binary: bin Log file: /home/jun/workspace_sdx/VideoFusion/Release/_sds/p0/vivado/prj/prj.runs/impl_1/runme.log :
ERROR: [VPL-4] Design failed to meet timing.
Failed timing checks (paths):
{zcu102_rv_ss_i/zynq_ultra_ps_e_0/inst/PS8_i/MAXIGP0ACLK --> zcu102_rv_ss_i/axi_interconnect_hpm0/m14_couplers/auto_cc/inst/gen_clock_conv.gen_sync_conv.gen_conv_write_ch.w_sync_clock_converter/gen_sync_clock_converter.m_tvalid_r_reg/D}
Please check the routed checkpoint (dr_routed_timing.dcp) and timing summary report (dr_timing_summary.rpt) for more information.
ERROR: [VPL 60-704] Integration error, problem implementing dynamic region, route_design ERROR
ERROR: [VPL 60-806] Failed to finish platform linker
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling '/home/jun/Programs/Xilinx2018.2/SDx/2018.2/bin/vpl --iprepo /home/jun/workspace_sdx/VideoFusion/Release/_sds/iprepo/repo --iprepo /home/jun/Programs/Xilinx2018.2/SDx/2018.2/data/ip/xilinx --platform /home/jun/zcu102-rv-ss-2018-2/zcu102_rv_ss/zcu102_rv_ss.xpfm --temp_dir /home/jun/workspace_sdx/VideoFusion/Release/_sds/p0 --output_dir /home/jun/workspace_sdx/VideoFusion/Release/_sds/p0/vpl --input_file /home/jun/workspace_sdx/VideoFusion/Release/_sds/p0/.xsd/top.bd.tcl --target hw --save_temps --kernels w0_xf_boxFilter:w3_xf_add:w2_xf_subtract:w1_xf_multiply:w4_xf_calcHist:adapter --webtalk_flag SDSoC --remote_ip_cache /home/jun/workspace_sdx/ip_cache --xp "vivado_prop:run.impl_1.{STEPS.PHYS_OPT_DESIGN.ARGS.MORE OPTIONS}={-directive Explore}" --xp "vivado_prop:run.impl_1.{STEPS.ROUTE_DESIGN.ARGS.MORE OPTIONS}={-directive Explore}" --xp "param:compiler.deleteDefaultReportConfigs=false" '
sds++ log file saved as /home/jun/workspace_sdx/VideoFusion/Release/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
sds++ completed at Tue Mar 19 16:45:02 UTC 2019
Hi @microlijun
Go to Debug or Release folder based on your active build configuration.
Navigate to _sds/p0/vivado/prj/prj.runs/impl_1
Please check for dr_timing_summary.rpt
Send it to me.
Best Regards,
Nutan
Visitor microlijun
Hi @nutang
Here is the timing report. Thank you.
Best Regards,
Jun
Hi @microlijun
Best Regards,
Nutan
Visitor microlijun
Hi @nutang ,
It works. Thank you so much.
Hi @microlijun
Please accept my post as a solution.
https://forums.xilinx.com/t5/SDSoC-Environment-and-reVISION/Integration-error-while-building-project-in-SDSoC/m-p/954106/highlight/true#M3784
Best Regards,
Nutan
