Is it possible to use other clocks in SDSoC?
Hello everyone,
I have a simple question:
Is it possible to use other clock frequencies for the hardware accelerators and/or the data movers other than the four suggested by the tool?
Cerilet
Re: Is it possible to use other clocks in SDSoC?
Hi cerilet,
In SDSoC, clock frequencies are a property of the platform, not the application. To change the clock frequencies you'll need to create a custom version of the built-in platform that you're using. When creating a platform, you can specify how every many clocks you want (at least one) at whatever frequencies you want. You do this by configuring the four clocks available from the Zynq processor block in Vivado. Then you need to use the SDSoC Tcl APIs to export the Vivado project info into a format that SDSoC can read.
UG1146 (2016.3 version) can be found here:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug1146-sdsoc-platform-development.pdf
And the relevant clock Tcl APIs can be found on page 42.
Sam
Hi cerilet,
Sam
I guess that'll take considerable amount of time to get it done.
Thanks for your quick reply, Sam.
