Participant urvish@htic
Making a Submodule using SDSoC
Hello!
I want to make a sub-module for an image procesing application using SDSoC. My entire design is designed using Vivado, is it possible to export the SDSoC design as an IP/submodule in my current design?
Thanks & Regards,
Urvish
Best Regards,
Urvish
Tags (2)
Re: Making a Submodule using SDSoC
urvish@htic
You want to integrate SDSoC design in your vivado design. Am I right?
Correct me if my understanding is wrong.
Best Regards,
Nutan
Yes. You are right.
Best Regards,
Urvish
Hi urvish@htic
After building your SDSoC project, you can go to debug/run folder (based on your active build configuration)
Navigate to _sds/p0/vivado/prj
You can see vivado project which will have sdsoc design integrated in it.
Please check if that is what you need.
Best Regards,
Nutan
Hello @nutang,
I cannot see any folder named "vivado" in that directory. I can see some IP repositories being created. Can I export them into my Vivado design? If yes, how to do that?
Best Regards,
Urvish
Hi urvish@htic
Looks like your SDSoC build is not completed or not successful.
The tool flow contains the step which creates the vivado project.
Best Regards,
Nutan
Why not use HLS for the submodule ?
