Out of memory when running OpenCL application on ZCU102
I have a custom OpenCL application targeting the ZCU102 device.
Emulation runs fine and the FPGA binary is built correctly but execution fails.
Any advice on how to find the cause of this "Out of memory: Kill process XXX" problem ?
root@zcu102:/mnt# source ./init.sh
insmod: can't insert '/mnt/zocl.ko': File exists
root@zcu102:/mnt# export XILINX_OPENCL=/mnt/embedded_root/
root@zcu102:/mnt#
root@zcu102:/mnt# time ./pointcloud2_to_image_fpga
init
done
platform Name: Xilinx
Vendor Name : Xilinx
Found Platform
XCLBIN File Name: pointcloud2_to_image
INFO: Importing ./pointcloud2_to_image.xclbin
Loading: './pointcloud2_to_image.xclbin'
[ 1467.541436] zocl-scheduler- invoked oom-killer: gfp_mask=0x16040c0(GFP_KERNEL|__GFP_COMP|__GFP_NOTRACK), nodemask=(null), order=0, oom_score_adj=0
[ 1467.554598] CPU: 1 PID: 2334 Comm: zocl-scheduler- Tainted: G O 4.14.0 #3
[ 1467.562473] Hardware name: ZynqMP ZCU102 Rev1.0 (DT)
[ 1467.567418] Call trace:
[ 1467.569857] [<ffffff8008088c58>] dump_backtrace+0x0/0x368
[ 1467.575234] [<ffffff8008088fd4>] show_stack+0x14/0x20
[ 1467.580270] [<ffffff80089ecb78>] dump_stack+0x9c/0xbc
[ 1467.585304] [<ffffff800813b248>] dump_header.isra.6+0x7c/0x194
[ 1467.591119] [<ffffff800813a8b8>] oom_kill_process+0x280/0x500
[ 1467.596848] [<ffffff800813ae68>] out_of_memory+0xe0/0x3e8
[ 1467.602231] [<ffffff800813fed8>] __alloc_pages_nodemask+0xa20/0xad8
[ 1467.608483] [<ffffff8008187634>] cache_alloc_refill+0xd4/0x690
[ 1467.614297] [<ffffff8008187d68>] kmem_cache_alloc+0xa0/0xd0
[ 1467.619854] [<ffffff8008174304>] alloc_vmap_area.isra.9+0x64/0x350
[ 1467.626017] [<ffffff8008174684>] __get_vm_area_node.isra.10+0x94/0x198
[ 1467.632527] [<ffffff80081750c4>] get_vm_area_caller+0x34/0x40
[ 1467.638257] [<ffffff8008095db8>] __ioremap_caller+0x68/0xf0
[ 1467.643811] [<ffffff8008095e50>] __ioremap+0x10/0x18
[ 1467.648769] [<ffffff8000a18148>] penguin_query+0x70/0x210 [zocl]
[ 1467.654757] [<ffffff8000a1863c>] scheduler+0x19c/0x410 [zocl]
[ 1467.660480] [<ffffff80080b908c>] kthread+0x12c/0x130
[ 1467.665427] [<ffffff8008084a90>] ret_from_fork+0x10/0x18
[ 1467.670740] Mem-Info:
[ 1467.672990] active_anon:20233 inactive_anon:3634 isolated_anon:0
[ 1467.672990] active_file:35 inactive_file:0 isolated_file:0
[ 1467.672990] unevictable:0 dirty:1 writeback:0 unstable:0
[ 1467.672990] slab_reclaimable:1111 slab_unreclaimable:667662
[ 1467.672990] mapped:1974 shmem:6015 pagetables:140 bounce:0
[ 1467.672990] free:271683 free_pcp:412 free_cma:258523
[ 1467.706186] Node 0 active_anon:80932kB inactive_anon:14536kB active_file:140kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:7896kB dirty:4kB writeback:0kB shmem:24060kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 0kB writeback_tmp:0kB unstable:0kB all_unreclaimable? yes
[ 1467.733164] DMA free:1064156kB min:22384kB low:27980kB high:33576kB active_anon:6316kB inactive_anon:0kB active_file:0kB inactive_file:4kB unevictable:0kB writepending:0kB present:2096128kB managed:2014576kB mlocked:0kB kernel_stack:16kB pagetables:8kB bounce:0kB free_pcp:800kB local_pcp:0kB free_cma:1034092kB
[ 1467.760589] lowmem_reserve[]: 0 1985 1985
[ 1467.764573] Normal free:22576kB min:22668kB low:28332kB high:33996kB active_anon:74616kB inactive_anon:14536kB active_file:16kB inactive_file:116kB unevictable:0kB writepending:4kB present:2097152kB managed:2032640kB mlocked:0kB kernel_stack:1504kB pagetables:552kB bounce:0kB free_pcp:844kB local_pcp:0kB free_cma:0kB
[ 1467.792622] lowmem_reserve[]: 0 0 0
[ 1467.796080] DMA: 1135*4kB (UMEC) 1370*8kB (UMEC) 657*16kB (UMEC) 134*32kB (UMC) 2*64kB (UC) 4*128kB (C) 2*256kB (C) 1*512kB (C) 2*1024kB (C) 3*2048kB (C) 250*4096kB (C) = 1064156kB
[ 1467.812151] Normal: 1076*4kB (UME) 1501*8kB (ME) 338*16kB (UME) 29*32kB (UM) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 22648kB
[ 1467.825086] 6053 total pagecache pages
[ 1467.828800] 0 pages in swap cache
[ 1467.832105] Swap cache stats: add 0, delete 0, find 0/0
[ 1467.837312] Free swap = 0kB
[ 1467.840170] Total swap = 0kB
[ 1467.843042] 1048320 pages RAM
[ 1467.845991] 0 pages HighMem/MovableOnly
[ 1467.849813] 36516 pages reserved
[ 1467.853024] 262144 pages cma reserved
[ 1467.856742] Out of memory: Kill process 2535 (pointcloud2_to_) score 17 or sacrifice child
[ 1467.864954] Killed process 2535 (pointcloud2_to_) total-vm:539476kB, anon-rss:67496kB, file-rss:8kB, shmem-rss:4268kB
Killed
real 2m29.051s
user 1m2.635s
sys 0m37.160s
Best,
L30nardo SV
Tags (3)
Re: Out of memory when running OpenCL application on ZCU102
Hi @leonardo.solis
Okay. I will verify this issue. meanwhile let me provide you a patch for 2018.2
Best Regards,
Nutan
Hi @leonardo.solis
This is a known issue. It is fixed in 2018.3
Kindly try with 2018.3 release.
If issue still persists, kindly let us know.
Best Regards,
Nutan
Hi @nutang,
Many thanks for the quick reply.
We have installed v2018.3 but couldn't build even the "hello_world" example: https://github.com/Xilinx/SDSoC_Examples/tree/master/ocl/getting_started/hello_vadd_ocl.
The reason is that the OpenCL headers and other files required for building are simply missing within the v2018.3 installation path. To give you an idea, here is a comparison wrt to v2018.2:
% ls 2018.2/runtime/include/1_2/CL/
cl2.hpp     cl_d3d11.h              cl_ext.h     cl_gl.h cl.hpp         opencl.h
cl_d3d10.h  cl_dx9_media_sharing.h  cl_gl_ext.h  cl.h cl_platform.h
% ls 2018.3/runtime/include/1_2/CL/
ls: cannot access '2018.3/runtime/include/1_2/CL/': No such file or directory
% ls 2018.2/runtime/lib/aarch64/
libxilinxopencl.so
% ls 2018.3/runtime/lib/aarch64/
ls: cannot access '2018.3/runtime/lib/aarch64/': No such file or directory
I have searched those files under the whole 2018.3 installation path but couldn't find any of them.
The installation process finished successfully so: is there is any additional step for obtaining the runtime files for SDSoC?
I have read that for SDAccel boards, runtime files should be downloaded separately:
https://forums.xilinx.com/t5/SDAccel/SDAccel-2018-3-examples-Error-XILINX-XRT-is-not-defined/td-p/921905
Any hint would be really apprecciated!
Leonardo
Best,
L30nardo SV
Hi @leonardo.solis
Best Regards,
Nutan
Hi @nutang,
Yes, meanwhile a patch would be nice for 2018.2.
Either privately or a publicly sharing it would be fine for me.
Thanks!
Leonardo
Best,
L30nardo SV
