Resnet50 application error in sdsoc
I am working on sdsoc development environment to build resnet50 as standalone applicatio.  When i build the project in sdosc I am facing below errors
:08:22 **** Build of configuration Debug for project resnet50 ****
make all
Building file: ../src/resnet50.cpp
Invoking: ARM A53 Linux g++ compiler
aarch64-linux-gnu-g++ -Wall -O2 -I"/home/administrator/AI_WORK/AI-sdsoc/include" -I/usr/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gstreamer-1.0 -I/usr/lib/gstreamer-1.0/include -c -fPIC -fpermissive -fmessage-length=0 -MT"src/resnet50.o" --sysroot= -MMD -MP -MF"src/resnet50.d" -MT"src/resnet50.o" -o "src/resnet50.o" "../src/resnet50.cpp"
Finished building: ../src/resnet50.cpp
Building target: resnet50.elf
Invoking: ARM A53 Linux g++ linker
aarch64-linux-gnu-g++ -L"/home/administrator/AI_WORK/AI-sdsoc/lib" --sysroot= -o "resnet50.elf" ./src/resnet50.o -ln2cube -ldputils -ldpucore -lopencv_core -lopencv_imgcodecs
/home/administrator/SDSOC-SETUP/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: cannot find crt1.o: No such file or directory
/home/administrator/SDSOC-SETUP/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: cannot find crti.o: No such file or directory
makefile:45: recipe for target 'resnet50.elf' failed
/home/administrator/SDSOC-SETUP/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: cannot find -lopencv_core
/home/administrator/SDSOC-SETUP/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: cannot find -lopencv_imgcodecs
/home/administrator/SDSOC-SETUP/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: cannot find -lm
/home/administrator/SDSOC-SETUP/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: cannot find -lc
/home/administrator/SDSOC-SETUP/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/bin/../lib/gcc/aarch64-linux-gnu/7.3.1/../../../../aarch64-linux-gnu/bin/ld: cannot find crtn.o: No such file or directory
collect2: error: ld returned 1 exit status
make: *** [resnet50.elf] Error 1
I don't know from where opencv is taking in build I am  not able to find . Could any one suggest me how to build the project with out above errors.
Raghuram
Re: Resnet50 application error in sdsoc
Hi @raghuram1a
Right click on your project and navigate to C/C++ build settings-> Settings-> SDS++ linker -> libraries
Best Regards,
Nutan
