SDS compiler error with multidimensional arrays
Hi All,
I'm compiling a project on SDx and a compiler error appear when I want to synthesize and accelerator with multidimensional arrays as input parameters.
This is the error generated:
Generating data motion network
INFO: [DMAnalysis 83-4494] Analyzing hardware accelerators...
INFO: [DMAnalysis 83-4497] Analyzing callers to hardware accelerators...
WARNING: [DMAnalysis 83-4492] Unable to determine the memory attributes passed to rMb1 of function inter_luma_double_bizero_skip at /home/lorenzo/phd/ws_vivado/sdx/h264/src/slice.c:214, please use mem_attribute pragma to specify
opt: /scratch/builds/2018.3/continuous/2018_12_06_2405991/build/swig/products/sdx/soc/ext/llvm_clang/v3.9/llvm/lnx64/llvm/include/llvm/IR/CallSite.h:159: ValTy* llvm::CallSiteBase<FunTy, BBTy, ValTy, UserTy, UseTy, InstrTy, CallTy, InvokeTy, IterTy>::getArgument(unsigned int) const [with FunTy = llvm::Function; BBTy = llvm::BasicBlock; ValTy = llvm::Value; UserTy = llvm::User; UseTy = llvm::Use; InstrTy = llvm::Instruction; CallTy = llvm::CallInst; InvokeTy = llvm::InvokeInst; IterTy = llvm::Use*]: Assertion `arg_begin() + ArgNo < arg_end() && "Argument # out of range!"' failed.
#0 0x000000000129cef5 llvm::sys::PrintStackTrace(llvm::raw_ostream&) (/tools2/Xilinx/SDx/2018.3/bin/../llvm-clang/lnx64/llvm/bin/opt+0x129cef5)
#1 0x000000000129af1e llvm::sys::RunSignalHandlers() (/tools2/Xilinx/SDx/2018.3/bin/../llvm-clang/lnx64/llvm/bin/opt+0x129af1e)
#2 0x000000000129b042 SignalHandler(int) (/tools2/Xilinx/SDx/2018.3/bin/../llvm-clang/lnx64/llvm/bin/opt+0x129b042)
#3 0x00007fa3f4fce6d0 __restore_rt (/lib64/libpthread.so.0+0xf6d0)
#4 0x00007fa3f3b44277 __GI_raise (/lib64/libc.so.6+0x36277)
#5 0x00007fa3f3b45968 __GI_abort (/lib64/libc.so.6+0x37968)
#6 0x00007fa3f3b3d096 __assert_fail_base (/lib64/libc.so.6+0x2f096)
#7 0x00007fa3f3b3d142 (/lib64/libc.so.6+0x2f142)
#8 0x00007fa3f37fccb4 (/tools2/Xilinx/SDx/2018.3/bin/../lib/lnx64.o/XidanePass.so+0x6acb4)
#9 0x00007fa3f37dd710 _init (/tools2/Xilinx/SDx/2018.3/bin/../lib/lnx64.o/XidanePass.so+0x4b710)
#10 0x00007fa3f37f4874 (/tools2/Xilinx/SDx/2018.3/bin/../lib/lnx64.o/XidanePass.so+0x62874)
#11 0x0000000000e86094 llvm::legacy::PassManagerImpl::run(llvm::Module&) (/tools2/Xilinx/SDx/2018.3/bin/../llvm-clang/lnx64/llvm/bin/opt+0xe86094)
#12 0x00000000005ff0a3 main (/tools2/Xilinx/SDx/2018.3/bin/../llvm-clang/lnx64/llvm/bin/opt+0x5ff0a3)
#13 0x00007fa3f3b30445 __libc_start_main (/lib64/libc.so.6+0x22445)
#14 0x0000000000642e99 _start (/tools2/Xilinx/SDx/2018.3/bin/../llvm-clang/lnx64/llvm/bin/opt+0x642e99)
Stack dump:
0.	Program arguments: /tools2/Xilinx/SDx/2018.3/bin/../llvm-clang/lnx64/llvm/bin/opt -load /tools2/Xilinx/SDx/2018.3/bin/../lib/lnx64.o/XidanePass.so -disable-output -mem2reg -basicaa -XidanePass --dmclkid 1 --repo /home/lorenzo/phd/ws_vivado/sdx/h264/Release/_sds/.cdb/xd_ip_db.xml --dmdb /tools2/Xilinx/SDx/2018.3/data/DM.db -os linux -processor cortex-a53 -partition 0 -perfest
1.	Running pass 'Data motion analysis and network generation' on module '<stdin>'.
/tools2/Xilinx/SDx/2018.3/bin/XidanePass: line 9:  5766 Aborted                 (core dumped) ${BIN_DIR}/../llvm-clang/lnx64/llvm/bin/opt -load ${BIN_DIR}/../lib/lnx64.o/XidanePass.so -disable-output -mem2reg -basicaa -XidanePass ${ARGS} < sds_all.o
Data motion generation exited with return code -2
- exited unexpectedly
sds++ log file saved as /home/lorenzo/phd/ws_vivado/sdx/h264/Release/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
make: *** [h264.elf] Error 1
I've been able to avoid this error only flattening the arrays - form multidimensional to monodimensional. Applying the SDS pragma mem_attrribute does not solve the problem in my case.
Does it mean that the C/C++ code defining the hardware accelerators have to be written such that all the input arrays of the target functions are monodimensional? Or there is another way to avoid this problem?
Lorenzo
Teacher xilinxacct
Re: SDS compiler error with multidimensional arrays
@lorenzoferretti
Are the sizes of the dimension fully specified where they are used?
e.g. a[10][20]   not a[ ][ ] or *a ... or something like that
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed. :-)
Yes, the sizes of the array dimensions are fully specified.
The only way I have found to get rid of the error is flattening the arrays completely, also in this case specifying the single resulting dimension.
Lorenzo
