zhanghao270
SDSOC project build ERROR
I build a customized platform (called: Miz_sys) for my Zynq-7000-based board: MIZ 7XB.
and then I set up a app project to test it.
it is an empty project,with little code:
int main()
    while(1);
   return 0;
but when I complie it, turns out ERROR:
11:23:05 **** Build of configuration Debug for project Miz_empty_test ****
make pre-build main-build
sdsoc_make_clean Debug
Analyzing object files
... /mnt/workspace/MZ7XB_board_SDx/Miz_empty_test/Debug/src/main.o
Generating data motion network
INFO: [DMAnalysis 83-4494] Analyzing hardware accelerators...
INFO: [DMAnalysis 83-4496] No hardware accelerators specified.
ERROR: [DMAnalysis 83-1349] Component type Miz_sys not found in IP repository database
who can help me to solve the problem? thanks!
stephenm
Can you share the DSA file used?
zhanghao270
nevermind,inspired by the solution , I found there was something wrong when Setting Platform Properties,
below are my custom pfm.tcl files:
this is before:
set_property PFM_NAME "Xilinx.com:MIZ_board:Miz_7XB:1.0" [get_files /mnt/workspace/MZ7XB_board_SDx/Hardware_platform/Miz_sys/Miz_sys.srcs/sources_1/bd/system/system.bd]
this is after:
set_property PFM_NAME "Xilinx.com:MIZ_board:Miz_sys:1.0" [get_files /mnt/workspace/MZ7XB_board_SDx/Hardware_platform/Miz_sys/Miz_sys.srcs/sources_1/bd/system/system.bd]
and the project which I used to build the platform is called Miz_sys,
so I think the name  was the point.
Thank you!
