SDSOC2018.3添加kcf代码,出现arm_neon.h error: unknown type 问题
环境: SDSOC 2018.3,zcu102-rv-ss-2018-3,xfopencv2018.3
以下粘贴部分log:
D:/program/XilinxSDSoC2018.3/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:39:9: error: unknown type name '__Int32x2_t'; did you mean '__int32_t'?
typedef __Int32x2_t int32x2_t;
__int32_t
D:\program\XilinxSDSoC2018.3\zcu102-rv-ss-2018-3\zcu102-rv-ss-2018-3\zcu102_rv_ss\sw\a53_linux\a53_linux\sysroot\aarch64-xilinx-linux\usr\include\bits/types.h:40:20: note: '__int32_t' declared here
typedef signed int __int32_t;
D:/program/XilinxSDSoC2018.3/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:40:9: error: unknown type name '__Int64x1_t'; did you mean '__int64_t'?
typedef __Int64x1_t int64x1_t;
__int64_t
D:\program\XilinxSDSoC2018.3\zcu102-rv-ss-2018-3\zcu102-rv-ss-2018-3\zcu102_rv_ss\sw\a53_linux\a53_linux\sysroot\aarch64-xilinx-linux\usr\include\bits/types.h:43:25: note: '__int64_t' declared here
typedef signed long int __int64_t;
D:/program/XilinxSDSoC2018.3/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:41:9: error: unknown type name '__Float16x4_t'
typedef __Float16x4_t float16x4_t;
D:/program/XilinxSDSoC2018.3/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:42:9: error: unknown type name '__Float32x2_t'
typedef __Float32x2_t float32x2_t;
D:/program/XilinxSDSoC2018.3/SDK/2018.3/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.3.1/include\arm_neon.h:43:9: error: unknown type name '__Poly8x8_t'
Re: SDSOC2018.3添加kcf代码,出现arm_neon.h error: unknown type 问题
@yyt
Others with the same problem used this... https://forums.xilinx.com/t5/SDSoC-Environment-and-reVISION/xfopencv-include-hls-opencv-h-throw-errors/td-p/922252
Hope that helps
If so, please mark as solution accepted.
