SDSoC 2016.2 no SDEstimate option exists for build configuration
I am using SDSoC 2016.2 version and under build configuration, only SDrelease and SD debug exists. There is no SDEstimate option. How can I access that feature?
Parnian
In 2016.2, performance estimation can be run with any build configuration (SDDebug, SDRelease or one you create).
The SDEstimate build configuration is no longer created just for running performance estimation.
In the SDSoC Project Overview, check the Estimate Performance box. Next, when you build the project, the initial
Performance Estimation report is created. As in 2016.1, the Click Here link in the report runs the software only ELF
to collect runtime information and produces the final report.
