Visitor koziotis
SDSoC Program (zcu102 board) crashes with "Bus error" message, when using the sds_alloc_non_cacheable() and -O3 optimization level
Find following a very simple C program that crashes with the message "Bus error" when compiled with -O3 for
target platform zcu102 and target OS linux.
The program allocates a single array of bytes using the sds_alloc_non_cacheable() function.
It exhibits a very strange behavior and seems to be dependent on the initial value of the memory buffer.
In fact when changing initial value from 0 to 1 the problem disappears.
main.cpp:
#include <stdio.h>
#include <stdlib.h>
#include "sds_lib.h"
#define BYTESIZE 1024
int main(int argc, char** argv) {
  char * buf1 = (char *) sds_alloc_non_cacheable(BYTESIZE * sizeof(char) );
  printf("buf1 = %p\n", buf1);
  for (int i=0; i<BYTESIZE; i++) buf1[i] = 0; // not working
//for (int i=0; i<BYTESIZE; i++) buf1[i] = 1; //     working
Makefile:
APPSOURCES = main.cpp
EXECUTABLE = buggy.elf
PLATFORM = zcu102
OS = -target-os linux
SDSCC_FLAGS = -sds-pf ${PLATFORM}
CC = sds++ ${SDSCC_FLAGS}
IDIRS =
LDIRS =
LLIBS =
OLEVEL = -O3
CFLAGS = -Wall ${OLEVEL} -c ${IDIRS} ${OS}
LFLAGS = ${OLEVEL} ${LDIRS} ${LLIBS} ${OS}
SOURCES := $(patsubst %,./%,$(APPSOURCES))
OBJECTS := $(APPSOURCES:.cpp=.o)
DEPS := $(OBJECTS:.o=.d)
.PHONY: all
all: ${EXECUTABLE}
${EXECUTABLE}: ${OBJECTS}
    ${CC} ${OBJECTS} ${LFLAGS} -o $@
-include ${DEPS}
%.o: %.cpp
    ${CC} ${CFLAGS} $< -o $@
clean:
    ${RM} ${EXECUTABLE} ${OBJECTS}
ultraclean: clean
    ${RM} -rf _sds sd_card ${EXECUTABLE}.bit
    ${RM} -rf vivado* .Xil
When changing -O3 to -O0 the problem also disappears.
I would kindly request Xilinx, to get this solved in the upcoming SDSoC versions.
Thank you,
Michael Koziotis
Re: SDSoC Program (zcu102 board) crashes with "Bus error" message, when using the sds_alloc_non_cacheable() and -O3 optimization level
I grabbed your code, used the delivered zcu102 platform, set the sds++ opt to level -03 and was able to build this w/o issue in 2018.2.  What version of the tools are you running this on?
Visitor sat1903
I am facing the same issue on ZCU102 Board. There is no issue when building the code. But, when I am running the code, I find the bus error. Also, I am not facing the issue when I run it on emulation mode.
Issue is specific when the run the code on ZCU102 Board.
SDX Version - 2018.2
