SDSoC axi-stream example (mmult_hls_axis) Linting error: array of struct is not supported! @
Hello All,
I am trying to compile the <sdsoc_install_dir>/samples/hls_if/mmult_hls_axis  example using SDSoC
But I got this errors
ERROR: [SDSoC 0-0] Linting error: array of struct is not supported! ....
ERROR: [SDSoC 0-0] sdslint exited with non-zero code processing  .....
I was wondering if anybody can help.
Mohava
Re: SDSoC axi-stream example (mmult_hls_axis) Linting error: array of struct is not supported! @
It seems I shouldn't of defined __SDSVHLS__.
just more infromation
I am using SDSoC under windows 7
I have defined the __SDSVHLS__ macro
and the error is for  this part of code at line 67 of mmult.cpp file
void mmult(ap_axiu<32,1,1,1> A[A_NROWS*A_NCOLS],
ap_axiu<32,1,1,1> B[A_NCOLS*B_NCOLS],
ap_axiu<32,1,1,1> C[A_NROWS*B_NCOLS]) {
Mohava
