immwn
SDSoC build project failed
Hi. I installed SDx in Ubuntu. When I tried to build a project it failed saying "Part 'xc7z020' is not installed"
10:03:49 **** Incremental Build of configuration Release for project lab1 ****
make pre-build main-build
sdsoc_make_clean Release
Building file: ../src/madd.cpp
Invoking: SDS++ Compiler
sds++ -Wall -O3 -I"../src" -c -fmessage-length=0 -MT"src/madd.o" -MMD -MP -MF"src/madd.d" -MT"src/madd.o" -o "src/madd.o" "../src/madd.cpp" -sds-hw madd madd.cpp  -clkid 2 -sds-end -sds-hw mmult mmult.cpp  -clkid 2 -sds-end -sds-sys-config linux -sds-proc linux -sds-pf "/data2/Xilinxsoc/SDx/2018.2/platforms/zc702"
Processing -sds-hw block for madd
Create data motion intermediate representation
Performing accelerator source linting for madd
Performing pragma generation
INFO: [PragmaGen 83-3231] Successfully generated tcl script: /myfolder/SDx_workspace/lab1/Release/_sds/vhls/madd.tcl
Moving function madd to Programmable Logic
ERROR: [HLS 200-70] Part 'xc7z020' is not installed.
command 'ap_source' returned error code
    while executing
"source /myfolder/SDx_workspace/lab1/Release/_sds/vhls/madd_run.tcl"
    invoked from within
"hls::main /myfolder/SDx_workspace/lab1/Release/_sds/vhls/madd_run.tcl -l madd_vivado_hls.log"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
    invoked from within
"hls_proc $argv"
INFO: [Common 17-206] Exiting vivado_hls at Wed Aug 29 10:03:52 2018...
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling '/data2/Xilinx/Vivado/2018.2/bin/vivado_hls /myfolder/SDx_workspace/lab1/Release/_sds/vhls/madd_run.tcl -l madd_vivado_hls.log'sds++ log file saved as /myfolder/SDx_workspace/lab1/Release/_sds/reports/sds_madd.log
ERROR: [SdsCompiler 83-5004] Build failed
src/subdir.mk:24: recipe for target 'src/madd.o' failed
make: *** [src/madd.o] Error 1
10:03:52 Build Finished (took 2s.730ms)
How can I solve this?
Cheers
skalicky
Hi immwn
Which SDx did you install? Did you install SDAccel or SDSoC? When you were installing, which devices were selected for installation?
Can you run the installer again and show us the page where you choose which components to install (dont worry, you can cancel the installation and wont ruin your current installation).
Sam
immwn
Hi @skalicky, I installed both SDSoC and SDAccel. I have opted out the env path related to SDAccel and it solved the error related to xc7z020 platform. However, it still has the following errors
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling '/data2/Xilinxsoc/Vivado/2018.2/bin/vivado_hls /users/3/a1634023/SDx_workspace/lab1/Release/_sds/vhls/madd_run.tcl -l madd_vivado_hls.log'
 Cheers
stephenm
can you share the log file mentioned in your error message?
immwn
Hi @stephenm, gcc-multilib package was missing in Ubuntu. That caused the problem. I solved it following this thread https://bugs.launchpad.net/ubuntu/+source/xen/+bug/1725390
