SDSoC compile error: cannot find -lxilffs
hello,
I created a custom hw platform with some platform sample designs. The examples work fine in SDK but when I test them in SDSoC I get the following error:
Description	Resource	Path	Location	Type
cannot find -lxilffs	test1		 	C/C++ Problem
Common 17-39: 'generate_bsp' failed due to earlier errors. test1 C/C++ Problem
why is this?
thank you
Scholar hbucher
Re: SDSoC compile error: cannot find -lxilffs
@theultimatesource
Check that the BSP has xilffs included.
The default SDSOC BSP should have xilffs included. That is the SD card library.
hello @hbucher,
actually I cannot do that because BSP generation fails due to missing lxilffs:
ERROR: [Hsi 55-1450] Error: running generate_bsp.
Here is the console output:
10:53:46 **** Incremental Build of configuration Release for project test1 ****
make pre-build main-build
sdsoc_make_clean Release
Building target: test1.elf
Invoking: SDS++ Linker
sds++ --remote_ip_cache D:/SDSoC/ip_cache -o "test1.elf"  ./src/helloworld.o ./src/platform.o    -dmclkid 0  -mno-boot-files  -sds-sys-config config0_0 -sds-proc a9_0 -sds-pf "D:\SDSoC\platforms\MY_PLATFORM"
Validating feature ap_sdsoc
License available for feature ap_sdsoc
Removing implementation files from previous run
Analyzing object files
... D:/SDSoC/test1/Release/src/helloworld.o
... D:/SDSoC/test1/Release/src/platform.o
Generating data motion network
D:\SDSoC\test1\Release>C:\Xilinx\SDx\2017.4\llvm-clang\win64\llvm\bin\llvm-link.exe -o D:/SDSoC/test1/Release/_sds/.llvm/sds_all.o D:/SDSoC/test1/Release/_sds/.llvm/./src/helloworld.s D:/SDSoC/test1/Release/_sds/.llvm/./src/platform.s
D:\SDSoC\test1\Release>exit /b 0
D:\SDSoC\test1\Release\_sds\.llvm>opt -disable-output -mem2reg -basicaa -XidanePass --platform MY_PLATFORM --dmclkid 0 --repo D:/SDSoC/test1/Release/_sds/.cdb/xd_ip_db.xml --dmdb C:/Xilinx/SDx/2017.4/data/DM.db -os standalone -processor cortex-a9  0<sds_all.o
INFO: [DMAnalysis 83-4494] Analyzing hardware accelerators...
INFO: [DMAnalysis 83-4496] No hardware accelerators specified.
Skipping block diagram (BD), address map, port information and device registration for partition 0
Rewrite caller functions
Prepare hardware access API functions
Create accelerator stub functions
Compile hardware access API functions
Compile accelerator stub functions
Enable generation of hardware programming files
Software tracing enabled
Create board support package library
ERROR: [#UNDEF] Running Make Failed
ERROR: [Hsi 55-1444] Error(s) while running make
generate_bsp: Time (s): cpu = 00:00:01 ; elapsed = 00:00:20 . Memory (MB): peak = 154.402 ; gain = 3.863
ERROR: [Common 17-39] 'generate_bsp' failed due to earlier errors.
    while executing
"hsi::generate_bsp -dir D:/SDSoC/test1/Release/_sds/swstubs/standalone_bsp -compile"
    (file "D:/SDSoC/test1/Release/_sds/swstubs/standalone_bsp/create_bsp_post.tcl" line 7)
Link application ELF file
c:/xilinx/sdk/2017.4/gnu/aarch32/nt/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/6.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -lxilffs
collect2.exe: error: ld returned 1 exit status
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'arm-none-eabi-g++ -mcpu=cortex-a9 -mfpu=vfpv3 -mfloat-abi=hard -Wl,--build-id=none -specs=C:/Xilinx/SDx/2017.4/data/toolchain/aarch32-none.spec -Wl,-T -Wl,D:/SDSoC/platforms/MY_PLATFORM/sw/config0_0/lscript.ld   D:/SDSoC/test1/Release/src/helloworld.o D:/SDSoC/test1/Release/src/platform.o D:/SDSoC/test1/Release/_sds/swstubs/portinfo.o  -L D:/SDSoC/test1/Release/_sds/swstubs/standalone_bsp/ps7_cortexa9_0/lib  -L C:/Xilinx/SDx/2017.4/target/aarch32-none/lib -LD:/SDSoC/test1/Release/_sds/swstubs -Wl,--start-group -lxilffs -lgcc -lc -lstdc++ -Wl,--end-group -Wl,--start-group   -lxilffs -lxil  -lgcc -lc  -lsds_lib -lxlnk_stub -lgcc -lc -Wl,--end-group -o D:/SDSoC/test1/Release/_sds/swstubs/test1.elf'
sds++ log file saved as D:/SDSoC/test1/Release/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
make: *** [test1.elf] Fehler 1
10:54:30 Build Finished (took 43s.347ms)
Newbie duclongle
You can easy to build library for xilffs from this website http://www.wiki.xilinx.com/xilffs
And after that include your own lib xilffs into your project.
Long.
