Observer zxbzsb
SDSoC fatal error: 'pthread.h' file not found
I am having trouble using SDSoc. My project can only be successfully compiled through software functions. However, after I specified the hardware function, there was a problem with the compilation.
The pthread.h file is located in the following directory and I can find it. please help me!
Re: SDSoC fatal error: 'pthread.h' file not found
Hi @zxbzsb
did you try below answer, which I posted on your previous post?
You need to do dynamic linking of the pthread library. Navigate to C/C++ build settings->C/C++ Build-> Settings->SDS++ Linker->Miscellaneous->Linker Flags
add,
-rpath-link=<library path> and retry
Best Regards,
Nutan
