Observer bartokon
SDSoC openCV
Hello! I'm trying to create program based on open CV but I have no luck building it...
Also,  I cannot see example projects when creating new project on SDSoC. I have tried looking for git for them but no luck compiling it.... Should I use different builder? If yes please tell me what should I use...
I'm working on win10 os
In attachments, I'm including log file.
Thanks for help
Re: SDSoC openCV
Hi @bartokon
Xilinx opencv is specially designed for FPGA based platforms
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1233-xilinx-opencv-user-guide.pdf
Please refer above document for detailed information about xfopencv.
Here is the github repository
https://github.com/Xilinx/xfopencv
It is required to use reVision platform in order to use xilinx opencv library.
You can download reVision platforms here
https://github.com/Xilinx/reVISION-Getting-Started-Guide/blob/master/Docs/software-tools-system-requirements.md
Detailed procedure to compile xfopencv based examples is given in UG1233.
Best Regards,
Nutan
Observer bartokon
Re: SDSoC openCV
Dear @nutang,
Thanks for tips.
I'm trying to run OpenCV on zc702 but still no luck even with those files you gave me... I'm using windows10 machine.
I have created Ubuntu 18.04 LTS (WSL) on my pc, downloaded CMAKE, libraries for compiling and downloaded openCV from official gitRepo.
And I compiled them using (https://docs.opencv.org/2.4/doc/tutorials/introduction/crosscompilation/arm_crosscompile_with_cmake.html). Next I created libs for both zc702 and zcu102 and tried to mount compiled libraries and now I have this kind of error (sds.log)
  "Error when calling 'arm-linux-gnueabihf-g++", now I just don't know what should I do to fix it...
Please give me some more tips if you please,
Best regards,
Bartokon
