SDSoC problem with data mover with programmable packet length
I have a problem with data movers in SDSoC. I'm trying to understand how to move data from memory to custom IP core over AXI stream.
Here it is C code for my data mover:
#include <data_producer.h>
#pragma SDS data sys_port(dst_stream:axis_data_fifo_0_S_AXIS)
#pragma SDS data copy(src_mem[0:C_BUFFER_SIZE])
#pragma SDS data access_pattern(src_mem:SEQUENTIAL)
#pragma SDS data mem_attribute (src_mem:NON_CACHEABLE|PHYSICAL_CONTIGUOUS)
void data_producer(U8 src_mem[C_BUFFER_SIZE], U8 *dst_stream)
 #pragma HLS interface axis port=dst_stream
 static int i;
 for (i=0; i < C_BUFFER_SIZE ; i++)
      *dst_stream = src_mem[i];
C_BUFFER_SIZE is fixed at compile time. This works fine.
Then I changed the data_producer so that the amount of data can be defined at run time :
void data_producer(U8 src_mem[C_BUFFER_SIZE], U32 nbyte, U8 *dst_stream, U8 *err)
 if (nbyte>C_BUFFER_SIZE)
  *err = 1;
 static int i;
 for (i=0; i < nbyte ; i++)
 *err = 0;
This works only for the first two transfers; at the third one the system hungs because the data_producer never ends. What's wrong with it?
  Mariano
Re: SDSoC problem with data mover with programmable packet length
according to UG1235, when varying data transfer size, it should be #pragma SDS data copy(src_mem[0:nbyte]) in the latter case
Mariano
