Visitor myay
SDSoC profiling in emulator - ERROR: Counter physical address not mapped yet!
I am using the SDSoC Enviroment 2018.3 to develop an application for the zedboard. When using the emulator with profiling (with sds_util.h header) I get the following error during emulation: "ERROR: Counter physical address not mapped yet! ", and it appears twice. It appears during the call of start() and stop(). What does this mean and how can I solve this problem ?
My code structure is as follows:
sds_utils::perf_counter hw_ctr, sw_ctr;
for (int runs = 0; runs < NLOOP; runs++) {
  sw_ctr.start();
  // sw funtion calls
  sw_ctr.stop();
uint64_t sw_cycles = sw_ctr.avg_cpu_cycles();
Best,
Mikail
Re: SDSoC profiling in emulator - ERROR: Counter physical address not mapped yet!
Hi @myay
I am testing this scenario at my end.
I will update you in a while.
Best Regards,
Nutan
Hi @myay
I tested it at my end using below example which has same code, I did not see the issue.
https://github.com/Xilinx/SDSoC_Examples/blob/master/cpp/getting_started/array_partition/src/main.cpp
If possible, share your project in a personal message or I can provide you the option to share it in most secured way via Xilinx utility EZMOVE. I will analyse the code.
Basically, it is memory allocation issue.
Best Regards,
Nutan
Visitor myay
If it is difficult to solve the problem, does measuring time with chrono in SDSoC produce reliable results ?
Visitor myay
I couldn't find the problem, but if anyone faces a similar issue, the use of the sds_clock_counter() call to measure time works.
