Visitor xxu10
SDx Cannot find the top function in the design
I am new to the SDSoC so I started from the reVISION stacks. In the example project 'filter2D', I just replaced the function xf::filter2D with xf::Sobel or xf::GaussianBlur and I didn't change anything else. Then it gives me [SYNCHK 200-79] Cannot find the top function error. So can I replace the original algorithm in the example project 'filter2D' ? If I can, what else should I do?
Scholar xilinxacct
Re: SDx Cannot find the top function in the design
@xxu10
If I understand your question... it sounds like you 'essentially' changed the name of the top level module in your project. In the settings you have to change the name of the top level to match.
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed. :-)
