Visitor supanhappy
Sdsoc compile error
Hi, I've installed SDSoC and try to build some programs using makefile in the samples/mmult directory. But it terminates with some errors. I'm using ubuntu 16.04 and SDSoC 2016.4. Please help! Thank you!
/home/uadmin/EDA/xilinx/sdsoc/SDx/2016.3/SDK/gnu/aarch32/lin/gcc-arm-linux-gnueabi/arm-linux-gnueabihf/include/c++/5.2.1/cstddef:51:11: error: no member named 'max_align_t' in the global namespace
  using ::max_align_t;
Visitor yunchen.lo
Re: Sdsoc compile error
Are there any solutions?
Also have this error as well QQ
Visitor yunchen.lo
After trying 2 days, I finally found the reason.
In SdSOC 2016.4 installation, it will automatically find the oldest gcc and g++ compiler on your computer.
Originally, my computer have four version of gnu compilers: 4.6, 4.7, 5, 6, respectively.
The SDSOC installation always install gnu compiler 4.6.
However, the cross compiler compiler seems to build with higher version of gnu compiler(in my case 5 ).
Therefore cause it cannot find max_int.h not found in the global space of <csddef> header file.
I just list all the gnu compilers and delete the older version(in my case 4.6, 4.7, 5). Then re-install again!
Hope this can help you
Jason Lo
