Solution: CHaiDNN running in Windows
Hi guys,
I'm working with CHaiDNN. In its project creation guide (https://github.com/Xilinx/CHaiDNN/blob/master/BUILD_USING_SDX_GUI.md) says:
IMPORTANT : Initial release only supports SDx GUI build on Linux machines.
Well, I think I managed to make it run on Windows 7 64bits, and I just would like to share it with all the community.
I was getting this problem:
So, I went to https://releases.linaro.org/components/toolchain/binaries/latest/aarch64-linux-gnu/ and I downloaded gcc-linaro-7.3.1-2018.05-i686-mingw32_aarch64-linux-gnu.tar.xz
And then I added  the route of the bin folder to the PATH: C:\Users\PC-i7\Downloads\gcc-linaro-7.3.1-2018.05-i686-mingw32_aarch64-linux-gnu\bin
And finally, this is the result:
Important: The guide I mentioned before has some bugs. auSgemvTop does not exists, the function you have to add is called xiSgemvTop
回复: Solution: CHaiDNN running in Windows
Where did you add gcc-linaro-7.3.1-2018.05-i686-mingw32_aarch64-linux-gnu\bin in the SDSOC project?
I can't get it build under windows
Could you explain in a bit more detail how to  add this option
