USB Camera interfacing problem in opticalflow sample of reVISION stack 2018.3
I am using ZCU102 version 1.1 board and reVISION stack 2018.3 and trying to run opticalflow sample as indicated in
reVISION Getting Started Guide 2018.3 (UG1265) . Using video_source = usb camera and video_sink = display port.
when running gst-launch utility -
gst-launch-1.0 \
                xlnxvideosrc src-type="usbcam" ! \
               "video/x-raw, width=1920, height=1080, format=YUY2" ! \
               sdxopticalflow filter-mode=1 ! queue ! \
               xlnxvideosink sink-type="dp" sync=false fullscreen-overlay=true
got this on terminal
root@xilinx:/media/card# gst-launch-1.0 \
> xlnxvideosink sink-type="hdmi" sync=false fullscreen-overlay=true
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Redistribute latency...
ERROR: from element /GstPipeline:pipeline0/GstXlnxVideoSrc:xlnxvideosrc0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
../../../../gstreamer-1.12.2/libs/gst/base/gstbasesrc.c(2939): gst_base_src_loop (): /GstPipeline:pipeline0/GstXlnxVideoSrc:xlnxvideosrc0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:10.960039777
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
I am confirm that my display port is working because when use src-type="vivid"  it shows something in monitor.
I am using LOGiTECH QUiCK CAM PRO 9000 WEBCAM as usb camera. May be its a camera issue.
On the wiki page it says:
Dense Optical Flow - requires LI-IMX274MIPI-FMC or HDMI source or See3CAM_CU30 USB camera
Is one of  these components must to run Dense Optical Flow sample or can I use other USB Camera ?
Have seen similar post  Getting started with reVISION - needed equipment but not clear with answer's last portion.
Please advice me how can I solve this problem.
Thanks in advance ...
Re: USB Camera interfacing problem in opticalflow sample of reVISION stack 2018.3
Solved "Internal data stream error" using these command
gst-launch-1.0 \
"video/x-raw, width=1280, height=720" ! \
deleting format=YUY2 option and changing width and height values for this camera
Currect this values after testing gstreamer in ubuntu16.4 but don't know clearly why..
gst-launch-1.0 \
You can check the pixel format of your camera using v4l2-ctl command like this
$ v4l2-ctl --list-formats-ext -d /dev/video0
ioctl: VIDIOC_ENUM_FMT
	Index       : 0
	Type        : Video Capture
	Pixel Format: 'MJPG' (compressed)
			Interval: Discrete 0.033s (30.000 fps)
	Index       : 1
	Pixel Format: 'YUYV'
			Interval: Discrete 0.100s (10.000 fps)
I think your camera can support YUY2(YUYV)
Visitor xr3118
This works for me, but it works only for a logitech camera. I still get errors when using See3CAM_CU30 USB camera. Don't know why.
Visitor i_am_here
I got the zcu104 included usb camera (See3Cam) to work with the optical flow demo.
1. As stated in the reVision guide (2018.3), copy libopticalflow.so to /usr/lib & libgstsdxopticalflow to /usr/lib/gstreamer-1.0. This has to be done after every system boot.
2. Start demo by
gst-launch-1.0 xlnxvideosrc src-type="usbcam" ! "video/x-raw, width=1920, height=1080" ! sdxopticalflow filter-mode=1 ! queue ! xlnxvideosink sink-type="hdmi" plane-id=31 sync=false fullscreen-overlay=true
To give some constructive feedback to Xilinx regarding the reVision guide. I really think you should provide examples based on what’s in the box. E.g. the zcu104 is delivered with the See3Cam. In the reVision guide (2018.3), your’e using video source hardware (MIPI, HDMI & USB-Stereo) that isn’t available in the box and you haven’t provided the commands for how to run applicable demos using the included See3Cam.
