USB Camera interfacing problem in opticalflow sample of reVISION stack 2018.3
I am using ZCU102 version 1.1 board and reVISION stack 2018.3 and trying to run opticalflow sample as indicated in
reVISION Getting Started Guide 2018.3 (UG1265) . Using video_source = usb camera and video_sink = display port.
when running gst-launch utility -
gst-launch-1.0 \
                xlnxvideosrc src-type="usbcam" ! \
               "video/x-raw, width=1920, height=1080, format=YUY2" ! \
               sdxopticalflow filter-mode=1 ! queue ! \
               xlnxvideosink sink-type="dp" sync=false fullscreen-overlay=true
got this on terminal
root@xilinx:/media/card# gst-launch-1.0 \
> xlnxvideosink sink-type="hdmi" sync=false fullscreen-overlay=true
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Redistribute latency...
ERROR: from element /GstPipeline:pipeline0/GstXlnxVideoSrc:xlnxvideosrc0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
../../../../gstreamer-1.12.2/libs/gst/base/gstbasesrc.c(2939): gst_base_src_loop (): /GstPipeline:pipeline0/GstXlnxVideoSrc:xlnxvideosrc0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:10.960039777
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
I am confirm that my display port is working because when use src-type="vivid"  it shows something in monitor.
I am using LOGiTECH QUiCK CAM PRO 9000 WEBCAM as usb camera. May be its a camera issue.
On the wiki page it says:
Dense Optical Flow - requires LI-IMX274MIPI-FMC or HDMI source or See3CAM_CU30 USB camera
Is one of  these components must to run Dense Optical Flow sample or can I use other USB Camera ?
Have seen similar post  Getting started with reVISION - needed equipment but not clear with answer's last portion.
Please advice me how can I solve this problem.
Thanks in advance ...
Re: USB Camera interfacing problem in opticalflow sample of reVISION stack 2018.3
Solved "Internal data stream error" using these command
gst-launch-1.0 \
"video/x-raw, width=1280, height=720" ! \
deleting format=YUY2 option and changing width and height values for this camera
Currect this values after testing gstreamer in ubuntu16.4 but don't know clearly why..
gst-launch-1.0 \
You can check the pixel format of your camera using v4l2-ctl command like this
$ v4l2-ctl --list-formats-ext -d /dev/video0
ioctl: VIDIOC_ENUM_FMT
	Index       : 0
	Type        : Video Capture
	Pixel Format: 'MJPG' (compressed)
			Interval: Discrete 0.033s (30.000 fps)
	Index       : 1
	Pixel Format: 'YUYV'
			Interval: Discrete 0.100s (10.000 fps)
I think your camera can support YUY2(YUYV)
