Visitor morkc
Using openCV together with xfopenCV
I want to use xfopenCV and openCV together in opticalflow from the reVISION stack while using SDSoC.
Is it possible for openCV and xfopenCV to be used together with optical_flow_sds.cpp?
- I have confirmed that it can be built when the openCV header is included in gstdsxopticalflow.cpp.
- Among the functions that perform hardware acceleration, I am under the impression that an ordinary OpenCV (not xfOpenCV) cannot be used, so I want to use OpenCV's functionality outside of the hardware accelerator orientated functions.
In regards to opticalflow, I have confirmed the following:
1) If I include opencv2/opencv.hpp in optical_flow_sds.cpp, it displays an error saying "unknown type name".
#include <cmath>
#include <common/xf_common.h>
#include <imgproc/xf_dense_npyr_optical_flow.hpp>
#include <linux/videodev2.h>
#include <stdlib.h>
#include "optical_flow_sds.h"
#include "opencv2/opencv.hpp"
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:56:9: error: unknown type name '__Float32x4_t'
typedef __Float32x4_t float32x4_t;
        ^fatal error: too many errors emitted, stopping now [-ferror-limit=]ERROR: [SdsCompiler 83-5005] clang exited with non-zero code processing /home/fpga/workspace/opticalflow/opticalflow/src/optical_flow_sds.cpp
sds++ log file saved as /home/fpga/workspace/opticalflow/opticalflow/Release/_sds/reports/sds_opticalflow_sds.log
ERROR: [SdsCompiler 83-5004] Build failed
src/subdir.mk:18: recipe for target 'src/optical_flow_sds.o' failed
make: *** [src/optical_flow_sds.o] Error 1
2) When I take optical_flow_sds.cpp and include the OpenCV header file (opencv2/opencv.hpp), just as in the implementation example on the Xilinx website indicates, I get a build error that says "use of undeclared identifier '__builtin_addressof".
#include <cmath>
#include <stdlib.h>
#if __SDSCC__
#undef __ARM_NEON__#undef __ARM_NEON#include "opencv2/opencv.hpp"
#define __ARM_NEON__#define __ARM_NEON#else
#endif
In file included from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/bits/stl_pair.h:59:
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/bits/move.h:51:16: error: use of undeclared identifier '__builtin_addressof'
      { return __builtin_addressof(__r); }
               ^ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling '/opt/Xilinx/Vivado/2018.2/bin/vivado_hls /home/fpga/workspace/opticalflow/opticalflow/Release/_sds/vhls/read_f2d_input_run.tcl -l read_f2d_input_vivado_hls.log'sds++ log file saved as /home/fpga/workspace/opticalflow/opticalflow/Release/_sds/reports/sds_optical_flow_sds.log
Re: Using openCV together with xfopenCV
Hi @morkc
Please check if you have added opencv include path, library path in C/C++ Build settings
Best Regards,
Nutan
Visitor morkc
@nutang wrote:
Hi @morkc
@nutang
My include path for openCV is:
c/c++ Build Setting -> SDS++ Compiler -> Directories
"${SYSROOT}/usr/include"
/home/fpga/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv
My C++ build settings library is:
c/c++ Build Setting -> SDS++ Linker -> Libraries
opencv_core
opencv_ximgproc
You have something wrong somewhere because I have used OpenCV and xfOpenCV in Sdsoc successfully ! The information you supply is few so there is no detail solution.
Visitor morkc
If there is a specific piece of information that you think would be helpful in answering my question, please let me know.
I'm not quite sure what else to mention.
Any help would be much appreciated!
Emmmm......here is my process building projects when opencv and xfOpenCV in the same project with different boards : https://blog.csdn.net/wd1603926823/article/details/82867166
I am trying to build project which need opencv and xfOpenCV and HLS video functions in the same project with Sdx 2018.2 but i have failed several times .however ,I succeed with Vivado HLS 2018.2 ! Does it not be supported using HLS video functions in Sdsoc ?
Visitor morkc
I am going to go ahead and reword my question:
<Question>
In SDSoC, I would like to use both xfopenCV and openCV, which are from opticalflow in the reVISION stack (zcu104-rv-ss-2018-2), concurrently.
You can call openCV and xfopenCV functions from optical_flow_sds.cpp, correct? If I were to call both together in the same program, how should I adjust my OpenCV include path and library path from the SDSoC GUI?
@wd-hyj
Thank you very much for your reply! In regards to HLS video functions, I am not quite sure how that relates to the problem that I am facing, but if you would be so kind as to explain that part to me, I would greatly appreciate it.
