Vivado crash trying to accelerate HOGDescriptor with 16x16 cells
Greetings,
I'm working on trying to get HOGDescriptor to work with 16x16 cells and 32x32 blocks. I figured I'd request these parameters and work through expanding any bit-widths as necessary. Unfortunately Vivado HLS crashes.
I tested the hypothesis that it was crashing due to the compiler failing the asserts in xFDHOGDescriptor, but commenting them out results in the same crash.
The crash details are:
****** Vivado(TM) HLS - High-Level Synthesis from C, C++ and SystemC v2018.2 (64-bit)
  **** SW Build 2258646 on Thu Jun 14 20:03:12 MDT 2018
  **** IP Build 2256618 on Thu Jun 14 22:10:49 MDT 2018
    ** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
source C:/Xilinx/Vivado/2018.2/scripts/vivado_hls/hls.tcl -notrace
INFO: [HLS 200-10] Running 'C:/Xilinx/Vivado/2018.2/bin/unwrapped/win64.o/vivado_hls.exe'
INFO: [HLS 200-10] For user 'mnixon' on host '#############' (Windows NT_amd64 version 6.1) on Tue Dec 11 17:39:53 -0500 2018
INFO: [HLS 200-10] In directory 'C:/########/########/###_hog/Release/_sds/vhls'
INFO: [HLS 200-10] Creating and opening project 'C:/########/########/###_hog/Release/_sds/vhls/hog_descriptor_accel_1'.
INFO: [HLS 200-10] Adding design file 'C:/########/########/###_hog/src/xf_hog_descriptor_accel.cpp' to the project
INFO: [HLS 200-10] Creating and opening solution 'C:/########/########/###_hog/Release/_sds/vhls/hog_descriptor_accel_1/solution'.
INFO: [HLS 200-10] Cleaning up the solution database.
INFO: [HLS 200-10] Setting target device to ' xczu7ev-ffvc1156-2-e '
INFO: [SYN 201-201] Setting up clock 'default' with a period of 3.33333ns.
INFO: [SYN 201-201] Setting up clock 'default' with an uncertainty of 0.9ns.
INFO: [HLS 200-10] Analyzing design file 'C:/########/########/###_hog/src/xf_hog_descriptor_accel.cpp' ...
WARNING: [HLS 214-111] Static variables and non-static stream cannot be used inside a dataflow region: C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor.hpp:56:53
WARNING: [HLS 214-111] Static variables and non-static stream cannot be used inside a dataflow region: C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_kernel.hpp:67:50
INFO: [HLS 200-111] Finished Linking Time (s): cpu = 00:00:01 ; elapsed = 00:00:27 . Memory (MB): peak = 108.660 ; gain = 47.984
INFO: [HLS 200-111] Finished Checking Pragmas Time (s): cpu = 00:00:01 ; elapsed = 00:00:27 . Memory (MB): peak = 108.660 ; gain = 47.984
INFO: [HLS 200-10] Starting code transformations ...
INFO: [XFORM 203-501] Unrolling loop 'procLoop' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_pm.hpp:105) in function 'void xFHOGPhaseMagnitudeKernel<2544, 1152, 13, 2, 1, 19, 1, 1152>(hls::stream<StreamType<FORWARD_REFERENCE>::name>&, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, unsigned short, unsigned short)' completely.
INFO: [XFORM 203-501] Unrolling loop 'Plane_Loop2' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:320) in function 'void xFHOGgradientsKernel<2544, 1152, 0, 13, 1, 0, 19, 1, 1152, 1>(hls::stream<StreamType<FORWARD_REFERENCE>::name>*, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, unsigned short, unsigned short)' completely.
INFO: [XFORM 203-501] Unrolling loop 'Plane_Loop4' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:338) in function 'void xFHOGgradientsKernel<2544, 1152, 0, 13, 1, 0, 19, 1, 1152, 1>(hls::stream<StreamType<FORWARD_REFERENCE>::name>*, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, unsigned short, unsigned short)' completely.
INFO: [XFORM 203-501] Unrolling loop 'Plane_Loop6' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:381) in function 'void xFHOGgradientsKernel<2544, 1152, 0, 13, 1, 0, 19, 1, 1152, 1>(hls::stream<StreamType<FORWARD_REFERENCE>::name>*, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, unsigned short, unsigned short)' completely.
INFO: [XFORM 203-501] Unrolling loop 'Plane_Loop7' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:397) in function 'void xFHOGgradientsKernel<2544, 1152, 0, 13, 1, 0, 19, 1, 1152, 1>(hls::stream<StreamType<FORWARD_REFERENCE>::name>*, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, unsigned short, unsigned short)' completely.
INFO: [XFORM 203-501] Unrolling loop 'Plane_Loop5' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:409) in function 'void xFHOGgradientsKernel<2544, 1152, 0, 13, 1, 0, 19, 1, 1152, 1>(hls::stream<StreamType<FORWARD_REFERENCE>::name>*, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, unsigned short, unsigned short)' completely.
INFO: [XFORM 203-501] Unrolling loop 'Plane_Loop3' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:177) in function 'void xFHOGcomputeColGrad<2544, 1152, 0, 13, 1, 0, 19, 1, 1152, 1>(hls::stream<StreamType<FORWARD_REFERENCE>::name>*, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, StreamType<FORWARD_REFERENCE>::name (*) [3][(FORWARD_REFERENCE) >> (xfNPixelsPerCycle<FORWARD_REFERENCE>::datashift)], PixelType<FORWARD_REFERENCE>::name (*) [(xfNPixelsPerCycle<FORWARD_REFERENCE>::nppc) + (2)], PixelType<FORWARD_REFERENCE>::name (*) [(xfNPixelsPerCycle<FORWARD_REFERENCE>::nppc) + (2)], PixelType<FORWARD_REFERENCE>::name (*) [(xfNPixelsPerCycle<FORWARD_REFERENCE>::nppc) + (2)], PixelType<FORWARD_REFERENCE>::name*, PixelType<FORWARD_REFERENCE>::name*, StreamType<FORWARD_REFERENCE>::name&, StreamType<FORWARD_REFERENCE>::name&, unsigned short, ap_uint<13>, ap_uint<2>, ap_uint<2>, ap_uint<2>, bool)' completely.
INFO: [XFORM 203-501] Unrolling loop 'Plane_Loop4' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:227) in function 'void xFHOGcomputeColGrad<2544, 1152, 0, 13, 1, 0, 19, 1, 1152, 1>(hls::stream<StreamType<FORWARD_REFERENCE>::name>*, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, hls::stream<StreamType<FORWARD_REFERENCE>::name>&, StreamType<FORWARD_REFERENCE>::name (*) [3][(FORWARD_REFERENCE) >> (xfNPixelsPerCycle<FORWARD_REFERENCE>::datashift)], PixelType<FORWARD_REFERENCE>::name (*) [(xfNPixelsPerCycle<FORWARD_REFERENCE>::nppc) + (2)], PixelType<FORWARD_REFERENCE>::name (*) [(xfNPixelsPerCycle<FORWARD_REFERENCE>::nppc) + (2)], PixelType<FORWARD_REFERENCE>::name (*) [(xfNPixelsPerCycle<FORWARD_REFERENCE>::nppc) + (2)], PixelType<FORWARD_REFERENCE>::name*, PixelType<FORWARD_REFERENCE>::name*, StreamType<FORWARD_REFERENCE>::name&, StreamType<FORWARD_REFERENCE>::name&, unsigned short, ap_uint<13>, ap_uint<2>, ap_uint<2>, ap_uint<2>, bool)' completely.
INFO: [XFORM 203-501] Unrolling loop 'Compute_Grad_Loop_Gray' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:90) in function 'void xFHOGgradientCompute<1, 0, 13, 1, ap_uint<8>, 3>(PixelType<FORWARD_REFERENCE>::name*, PixelType<FORWARD_REFERENCE>::name*, FORWARD_REFERENCE (*) [FORWARD_REFERENCE], FORWARD_REFERENCE (*) [FORWARD_REFERENCE], FORWARD_REFERENCE (*) [FORWARD_REFERENCE])' completely.
INFO: [XFORM 203-501] Unrolling loop 'Extract_pixels_loop' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\common/xf_utility.h:73) in function 'void xfExtractPixels<1, 0, 0>(PixelType<FORWARD_REFERENCE>::name*, StreamType<FORWARD_REFERENCE>::name&, int)' completely.
INFO: [XFORM 203-501] Unrolling loop 'no_of_channel_loop' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_utility.hpp:165) in function 'void xFHOGReadFromStreamKernel<2544, 1152, 1, ap_uint<8>, ap_uint<8> >(hls::stream<FORWARD_REFERENCE>&, hls::stream<FORWARD_REFERENCE>*, unsigned short, unsigned short)' completely.
INFO: [XFORM 203-603] Inlining function 'xFHOGgradientXY<0, 13, 1>' into 'xFHOGgradientCompute<1, 0, 13, 1, ap_uint<8>, 3>' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:98).
INFO: [XFORM 203-603] Inlining function 'xFHOGgradientXY<0, 13, 1>' into 'xFHOGgradientCompute<1, 0, 13, 1, ap_uint<8>, 3>' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:94).
INFO: [XFORM 203-603] Inlining function 'ap_fixed_base<33, 32, false, (ap_q_mode)5, (ap_o_mode)3, 0>::operator<<' into 'xFSqrtHOG<16, 31, 31, (ap_q_mode)5, (ap_o_mode)0>' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_utility.hpp:707).
INFO: [XFORM 203-603] Inlining function 'ap_fixed_base<32, 31, false, (ap_q_mode)5, (ap_o_mode)3, 0>::operator>>=' into 'xFSqrtHOG<16, 31, 31, (ap_q_mode)5, (ap_o_mode)0>' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_utility.hpp:715).
INFO: [XFORM 203-603] Inlining function 'ap_fixed_base<34, 33, false, (ap_q_mode)5, (ap_o_mode)3, 0>::operator<<=' into 'xFSqrtHOG<16, 31, 31, (ap_q_mode)5, (ap_o_mode)0>' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_utility.hpp:716).
INFO: [XFORM 203-603] Inlining function 'ap_fixed_base<33, 32, false, (ap_q_mode)5, (ap_o_mode)3, 0>::operator>>' into 'xFSqrtHOG<16, 31, 31, (ap_q_mode)5, (ap_o_mode)0>' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_utility.hpp:719).
INFO: [HLS 200-111] Finished Standard Transforms Time (s): cpu = 00:00:01 ; elapsed = 00:00:28 . Memory (MB): peak = 144.289 ; gain = 83.613
INFO: [HLS 200-10] Checking synthesizability ...
INFO: [XFORM 203-602] Inlining function 'xFHOGReadFromStreamKernel<2544, 1152, 1, ap_uint<8>, ap_uint<8> >' into 'xFHOGReadFromStream<2544, 1152, 1, ap_uint<8>, ap_uint<8> >' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_utility.hpp:196) automatically.
INFO: [XFORM 203-602] Inlining function 'xf::Inverse8' into 'xf::DivideYByX8' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\core/xf_math.h:406) automatically.
INFO: [XFORM 203-602] Inlining function 'xf::DivideYByX8' into 'xf::Atan2LUT8' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\core/xf_math.h:551) automatically.
WARNING: [SYNCHK 200-77] The top function 'hog_descriptor_accel_1' (C:/########/########/###_hog/src/xf_hog_descriptor_accel.cpp:36) has no outputs. Possible cause(s) are: (1) Output parameters are passed by value; (2) intended outputs (parameters or global variables) are never written; (3) there are infinite loops.
INFO: [SYNCHK 200-10] 0 error(s), 1 warning(s).
INFO: [HLS 200-111] Finished Checking Synthesizability Time (s): cpu = 00:00:02 ; elapsed = 00:00:29 . Memory (MB): peak = 161.484 ; gain = 100.809
INFO: [XFORM 203-502] Unrolling all loops for pipelining in function 'xFSqrtHOG<16, 31, 31, (ap_q_mode)5, (ap_o_mode)0>' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_utility.hpp:684:3).
WARNING: [XFORM 203-505] Ignored pipeline directive for loop 'Loop-1' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_utility.hpp:703) because its parent loop or function is pipelined.
INFO: [XFORM 203-501] Unrolling loop 'Loop-1' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_utility.hpp:703) in function 'xFSqrtHOG<16, 31, 31, (ap_q_mode)5, (ap_o_mode)0>' completely.
INFO: [XFORM 203-102] Automatically partitioning streamed array 'in.V.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor.hpp:55) .
INFO: [XFORM 203-101] Partitioning array 'GradientValuesX.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:258) in dimension 1 completely.
INFO: [XFORM 203-101] Partitioning array 'GradientValuesY.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:259) in dimension 1 completely.
INFO: [XFORM 203-101] Partitioning array 'src_buf0.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:264) in dimension 1 completely.
INFO: [XFORM 203-101] Partitioning array 'src_buf1.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:265) in dimension 1 completely.
INFO: [XFORM 203-101] Partitioning array 'src_buf2.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:266) in dimension 1 completely.
INFO: [XFORM 203-101] Partitioning array 'buf.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:275) in dimension 1 completely.
INFO: [XFORM 203-101] Partitioning array 'in.V.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor.hpp:55) in dimension 1 completely.
INFO: [XFORM 203-101] Partitioning array 'src_buf0.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:264) in dimension 2 completely.
INFO: [XFORM 203-101] Partitioning array 'src_buf1.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:265) in dimension 2 completely.
INFO: [XFORM 203-101] Partitioning array 'src_buf2.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:266) in dimension 2 completely.
INFO: [XFORM 203-101] Partitioning array 'buf.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_gradients.hpp:275) in dimension 2 completely.
INFO: [XFORM 203-721] Changing loop 'Loop_1_proc' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor.hpp:62) to a process function for dataflow in function 'xf::HOGDescriptor<128, 64, 16, 32, 32, 16, 16, 9, 201924, 1, 1, 0, 3, 2544, 1152, 1>'.
WARNING: [XFORM 203-731] Internal stream variable 'phase_stream.V.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_kernel.hpp:67) is invalid: it has no data consumer.
WARNING: [XFORM 203-731] Internal stream variable 'mag_stream.V.V' (C:/########/zcu104-rv-ss-2018-2/zcu104_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv\imgproc/xf_hog_descriptor_kernel.hpp:67) is invalid: it has no data consumer.
Stack dump:
0.	Running pass 'Scalar propagation for dataflow pipeline' on module 'C:/########/########/###_hog/Release/_sds/vhls/hog_descriptor_accel_1/solution/.autopilot/db/a.o.1.bc'.
0x000007FEB1B51A69 (0x0000000009B321A2 0x000000000BC6DF80 0x000000000410FF20 0x0000000009B321A2), exp2() + 0x2148C9 bytes(s)
0x000007FEB177B95B (0x0000000009B32DD0 0x0000000009B32DD2 0x0000000009B32D01 0x000000000A646940), ?save_object_ptr@?$pointer_oserializer@Vxml_oarchive@archive@boost@@VTransition@DBFsm@fsmd@@@detail@archive@boost@@EEBAXAEAVbasic_oarchive@234@PEBX@Z() + 0x3A06FB bytes(s)
0x000007FEB1777998 (0x000000000CBC3A18 0x000000000CBC3A20 0x000000000A7D8AF0 0x000000000CBC3A20), ?save_object_ptr@?$pointer_oserializer@Vxml_oarchive@archive@boost@@VTransition@DBFsm@fsmd@@@detail@archive@boost@@EEBAXAEAVbasic_oarchive@234@PEBX@Z() + 0x39C738 bytes(s)
0x000007FEB177C638 (0x000000000CA69060 0x000000000C000178 0x0000000000000000 0x000000000C000168), ?save_object_ptr@?$pointer_oserializer@Vxml_oarchive@archive@boost@@VTransition@DBFsm@fsmd@@@detail@archive@boost@@EEBAXAEAVbasic_oarchive@234@PEBX@Z() + 0x3A13D8 bytes(s)
0x000007FEB177CC08 (0x00000000000000E4 0x0000000004110A49 0x0000000000000000 0x0000000000000000), ?save_object_ptr@?$pointer_oserializer@Vxml_oarchive@archive@boost@@VTransition@DBFsm@fsmd@@@detail@archive@boost@@EEBAXAEAVbasic_oarchive@234@PEBX@Z() + 0x3A19A8 bytes(s)
0x000007FEB108B779 (0x0000000000000000 0x00000000044F8FB0 0x0000000000000000 0x0000ADA5A5FEA0F3), ?main@Syn@@YAHHPEAPEAD@Z() + 0x2EF8F9 bytes(s)
0x000007FEB108A660 (0x0000000000000000 0x00000000041113D0 0x00000000044F8FB0 0x000000000A87C630), ?main@Syn@@YAHHPEAPEAD@Z() + 0x2EE7E0 bytes(s)
0x000007FEB0D484FC (0x0000000000000F51 0x0000000000000F51 0x00000000041113D0 0x0000000000000F48)
0x000007FED35DA85C (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000002A486D0), ?addOwnedOption@TclCommand@xpcl@@QEAAXPEAVOption@2@@Z() + 0x4AC bytes(s)
0x000007FED35DEC42 (0x000000000A7E9E90 0x000000000A7E9E8E 0x0000000008C08580 0x000000000F890E7B), ?setResultObj@TclCommand@xpcl@@QEAAXPEAUTcl_Obj@@@Z() + 0x52 bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000134 0x0000000002A50468 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x0000000008B647A0 0x0000000000000000 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F824FEC (0x0000000002B2B320 0x0000000002A486D0 0x0000000000000001 0x0000000002A486D0), Tcl_ExprObj() + 0x61C bytes(s)
0x000000000F7E2E8D (0x00000000070CF400 0x0000000000000003 0x0000000002A486D0 0x0000000006A64AF0), TclEvalObjEx() + 0x3AD bytes(s)
0x000000000F7E2ACD (0x0000000002A50410 0x0000000000468880 0x0000000002B2B320 0x000000000F874790), Tcl_EvalObjEx() + 0x1D bytes(s)
0x000007FEB235FDDB (0x0000000002A486D0 0x0000000002A486D0 0x0000000002A503F8 0x000000000F8AAC7D)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000003 0x0000000002A503F8 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x0000000008C12F60 0x0000000002A50000 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F8712F4 (0x0000000000000000 0x0000000002A486D0 0x0000000002A50000 0x000000000F8AAC7D), TclObjInterpProcCore() + 0x74 bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000004 0x0000000002A50000 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x0000000008C10F60 0x0000000000000000 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F7E2E8D (0x0000000008A2AFA0 0x0000000000000003 0x0000000002A486D0 0x0000000006A64AF0), TclEvalObjEx() + 0x3AD bytes(s)
0x000000000F7E2ACD (0x0000000002A4FFA0 0x0000000000468880 0x0000000002B2B320 0x000000000F874790), Tcl_EvalObjEx() + 0x1D bytes(s)
0x000007FEB235FDDB (0x0000000002A486D0 0x0000000002A486D0 0x0000000002A4FF88 0x000000000F8AAC7D)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000003 0x0000000002A4FF88 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x0000000006E109F0 0x0000000002A4FDF8 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F8712F4 (0x0000000000000000 0x0000000002A486D0 0x0000000002A4FDF8 0x000000000F83460F), TclObjInterpProcCore() + 0x74 bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000006 0x0000000002A4FDF8 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x0000000006E119F0 0x0000000002A4FC88 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F8712F4 (0x0000000000000000 0x0000000002A486D0 0x0000000002A4FC88 0xFFFFFFFFFFFFFFFF), TclObjInterpProcCore() + 0x74 bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000001 0x0000000002A4FC88 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x0000000008BF5470 0x0000000000000000 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F824FEC (0x0000000002B2B320 0x0000000002A486D0 0x0000000004114590 0x0000000004114540), Tcl_ExprObj() + 0x61C bytes(s)
0x000000000F7E2E8D (0x0000000002A4D6F0 0x0000000000000003 0x0000000002A486D0 0x00000000089D1C70), TclEvalObjEx() + 0x3AD bytes(s)
0x000000000F7E2ACD (0x0000000000000000 0x0000000000468880 0x0000000002B2B320 0x000000000F874790), Tcl_EvalObjEx() + 0x1D bytes(s)
0x000007FEB235FDDB (0x0000000002A486D0 0x0000000002A486D0 0x0000000008A52BF0 0x000000000F8AAC7D)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000003 0x0000000002A4FC18 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x0000000008BF5570 0x0000000008C05040 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F824D5D (0x0000000008C05AF0 0x0000000008C9F9F0 0x0000000000000000 0x0000000000000001), Tcl_ExprObj() + 0x38D bytes(s)
0x000000000F7ED73B (0x0000000002A486D0 0x0000000000000000 0x0000000006B4A010 0x0000000002A4FA60), TclDumpMemoryInfo() + 0x5D6B bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000003 0x0000000002A4FA60 0x0000000006B4A312), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F7E218E (0x0000000002A486D0 0x0000000006B4A010 0x0000000000000003 0x0000000000000003), Tcl_EvalEx() + 0x99E bytes(s)
0x000000000F7E2A38 (0x0000000002A486D0 0x0000000000000000 0x000007FEB1CA4BC4 0x0000000000000000), Tcl_Eval() + 0x38 bytes(s)
0x000007FEB0D2145C (0x0000000004115E70 0x000000000000004D 0x0000000000000000 0x0000000000000000)
0x000007FED35DA8A0 (0x00000000070D14D0 0x000000000F890E7B 0x0000000002A4F5A0 0x0000000002A486D0), ?addOwnedOption@TclCommand@xpcl@@QEAAXPEAVOption@2@@Z() + 0x4F0 bytes(s)
0x000007FED35DEC42 (0x0000000000000000 0x0000000002A486D0 0x0000000002A4F790 0x000000000F8AAC7D), ?setResultObj@TclCommand@xpcl@@QEAAXPEAUTcl_Obj@@@Z() + 0x52 bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000006 0x0000000002A4F788 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x0000000008A02B50 0x0000000002A4F588 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F8712F4 (0x0000000000000000 0x0000000002A486D0 0x0000000002A4F588 0x000000007775336B), TclObjInterpProcCore() + 0x74 bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000001 0x0000000002A4F588 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x00000000089E2260 0x0000000000000000 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F824FEC (0x0000000002B2B320 0x0000000002A486D0 0x00000000041171A0 0x0000000004117150), Tcl_ExprObj() + 0x61C bytes(s)
0x000000000F7E2E8D (0x00000000089F4AB0 0x0000000000000003 0x0000000002A486D0 0x00000000089D1C70), TclEvalObjEx() + 0x3AD bytes(s)
0x000000000F7E2ACD (0x0000000002A486D0 0x0000000000468880 0x0000000002B2B320 0x000000000F874790), Tcl_EvalObjEx() + 0x1D bytes(s)
0x000007FEB235FDDB (0x0000000002A486D0 0x0000000002A486D0 0x00000000045B00A0 0x000000000F8AAC7D)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000003 0x0000000002A4F518 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x00000000089E2560 0x00000000089D5030 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F824D5D (0x00000000089D52D0 0x00000000089EED10 0x0000000000000000 0x0000000000000001), Tcl_ExprObj() + 0x38D bytes(s)
0x000000000F7ED73B (0x0000000002A486D0 0x0000000000000000 0x000000000721D380 0x0000000002A4F360), TclDumpMemoryInfo() + 0x5D6B bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000003 0x0000000002A4F360 0x000000000721E586), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F7E218E (0x0000000002A486D0 0x000000000721D380 0x0000000000000003 0x0000000000000003), Tcl_EvalEx() + 0x99E bytes(s)
0x000007FEB0D2145C (0x0000000004118A80 0x000000000000008D 0x0000000000000000 0x0000000000000000)
0x000007FED35DA8A0 (0x0000000002A3BDF0 0x000000000F810AE5 0x00000000089F0FE9 0x0000000002A486D0), ?addOwnedOption@TclCommand@xpcl@@QEAAXPEAVOption@2@@Z() + 0x4F0 bytes(s)
0x000007FED35DEC42 (0x0000000000000000 0x0000000002A486D0 0x0000000002A4F058 0x000000000F8AAC7D), ?setResultObj@TclCommand@xpcl@@QEAAXPEAUTcl_Obj@@@Z() + 0x52 bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x000000000000000B 0x0000000002A4F058 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x00000000089F0DA0 0x0000000002A4EE88 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F8712F4 (0x0000000000000000 0x0000000002A486D0 0x0000000002A4EE88 0x000000000F8AAC3C), TclObjInterpProcCore() + 0x74 bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000001 0x0000000002A4EE88 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x00000000089DF860 0x0000000000000000 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F824FEC (0x0000000002B2B320 0x0000000002A486D0 0x0000000004119DB0 0x0000000004119D60), Tcl_ExprObj() + 0x61C bytes(s)
0x000000000F7E2E8D (0x0000000000000001 0x0000000000000003 0x0000000002A486D0 0x00000000089D1C70), TclEvalObjEx() + 0x3AD bytes(s)
0x000000000F7E2ACD (0x3065646FFFFFFFFF 0x0000000000468880 0x0000000002B2B320 0x000000000F874790), Tcl_EvalObjEx() + 0x1D bytes(s)
0x000007FEB235FDDB (0x0000000002A486D0 0x0000000002A486D0 0x0000000000004470 0x000000000F8AAC7D)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000003 0x0000000002A4EE18 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x0000000006DD6CC0 0x0000000006B1F470 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F824D5D (0x00000000089D3050 0x00000000070AF8F0 0x0000000000000000 0x0000000000000001), Tcl_ExprObj() + 0x38D bytes(s)
0x000000000F7ED73B (0x0000000002A486D0 0x0000000000000000 0x000000000757BBA0 0x0000000002A4EC60), TclDumpMemoryInfo() + 0x5D6B bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000003 0x0000000002A4EC60 0x000000000757C24E), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F7E218E (0x0000000002A486D0 0x000000000757BBA0 0x0000000000000003 0x0000000000000003), Tcl_EvalEx() + 0x99E bytes(s)
0x000007FEB0D2145C (0x000000000411B690 0x0000000000000011 0x0000000000000000 0x0000000000000000)
0x000007FED35DA8A0 (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000002A486D0), ?addOwnedOption@TclCommand@xpcl@@QEAAXPEAVOption@2@@Z() + 0x4F0 bytes(s)
0x000007FED35DEC42 (0x00000000089DDFD0 0x0000000000000000 0x0000000000000000 0x0000000000000002), ?setResultObj@TclCommand@xpcl@@QEAAXPEAUTcl_Obj@@@Z() + 0x52 bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000001 0x0000000002A4E850 0x00000000070C84E3), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F7E218E (0x0000000002A486D0 0x00000000070C7910 0x0000000000000001 0x0000000000000001), Tcl_EvalEx() + 0x99E bytes(s)
0x000000000F84B660 (0x0000000000000000 0x000007FEB2173F90 0x0000000000000000 0x0000000000000000), Tcl_FSEvalFileEx() + 0x250 bytes(s)
0x000007FEB0D1D163 (0x0000000000000000 0x0000000000000000 0x0000000000000000 0xFFFFFFFFFFFFFFFE)
0x000007FEB0D20BBA (0x000000000411BF40 0x0000000000000056 0x000000000411BF10 0x0000000000000056)
0x000007FED35DA8A0 (0x0000000000000001 0x000000000F82478C 0x0000000002AE45E0 0x0000000002A486D0), ?addOwnedOption@TclCommand@xpcl@@QEAAXPEAVOption@2@@Z() + 0x4F0 bytes(s)
0x000007FED35DEC42 (0x000000000411C468 0x000000000F8AAC7D 0x64735F2F65736165 0x0000000000000001), ?setResultObj@TclCommand@xpcl@@QEAAXPEAUTcl_Obj@@@Z() + 0x52 bytes(s)
0x000000000F7E11FC (0x0000077900000000 0x0000000000000002 0x0000000006EE42F0 0x0000000000000000), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F7E1681 (0x0000000006FC2BE0 0x0000000000000002 0x0000000000000007 0x000000000411C4C9), Tcl_EvalObjv() + 0x51 bytes(s)
0x000000000F7E2C37 (0x000000000000004D 0x000000000411C4C9 0x000000000000004D 0x0000000002C17E90), TclEvalObjEx() + 0x157 bytes(s)
0x000000000F7E2ACD (0x0000000000000002 0x0000000002AE4620 0x0000000002AE4620 0x0000000000000000), Tcl_EvalObjEx() + 0x1D bytes(s)
0x000007FEDBCB6465 (0x000000000411C8A8 0x00000000003A0000 0x000000000411C8A8 0x00000000003AD500), Rdi_hlstasks_Init() + 0x3635 bytes(s)
0x000007FEB99114E4 (0x0000000002A486D0 0x000000000411C8A8 0xFFFFFFFFFFFFFFFF 0x000000000F8344E3), ?eval_in_tcl_throw@task_manager@tcltasks@hdi@@SAHPEBD0_N@Z() + 0x254 bytes(s)
0x000007FEB99142F6 (0x000000000F8E5A20 0x0000000000000000 0x0000000004476070 0x000000000F8AAC3C), ?retrieve_except_msg_instance@task_manager@tcltasks@hdi@@SA_NAEAV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z() + 0x4C6 bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000004 0x0000000002A4E3F0 0x0000000004476070), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F7E218E (0x0000000002A486D0 0x0000000004476070 0x0000000000000004 0x0000000000000004), Tcl_EvalEx() + 0x99E bytes(s)
0x000000000F7E2D1E (0x0000000000000000 0x0000000000000000 0x0000000000000004 0x0000000000000006), TclEvalObjEx() + 0x23E bytes(s)
0x000000000F8705F9 (0x0000000000000001 0x0000000002A3AB30 0x0000000002A486D0 0x00000000004948BC), TclObjGetFrame() + 0x339 bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000006 0x0000000002A4E118 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x00000000004947E0 0x0000000002A4E028 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F8712F4 (0x0000000000000000 0x0000000002A486D0 0x0000000002A4E028 0x000000000F890E7B), TclObjInterpProcCore() + 0x74 bytes(s)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000002 0x0000000002A4E028 0xFFFFFFFFFFFFFFFF), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F826238 (0x0000000002A486D0 0x0000000004475D70 0x0000000000000000 0x0000000000000000), Tcl_ExprObj() + 0x1868 bytes(s)
0x000000000F824FEC (0x0000000000468880 0x0000000002A486D0 0xFFFFFFFFFFFFFFFE 0x000000000411DB80), Tcl_ExprObj() + 0x61C bytes(s)
0x000000000F7E2E8D (0x000000000411DC48 0x0000000000000004 0x0000000002A486D0 0x000000000446BDE0), TclEvalObjEx() + 0x3AD bytes(s)
0x000000000F7E2ACD (0x0000000002B2B320 0x0000000000468880 0x0000000000468880 0x00000000044A8050), Tcl_EvalObjEx() + 0x1D bytes(s)
0x000007FEB235FDDB (0x0000000002A486D0 0x0000000002A486D0 0x00000000004949E0 0x000000000F8AAC3C)
0x000000000F7E11FC (0x0000000000000000 0x0000000000000004 0x0000000002A4DE70 0x0000000000494A8A), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x000000000F7E218E (0x0000000002A486D0 0x0000000000494A8A 0x0000000000000004 0x0000000000000004), Tcl_EvalEx() + 0x99E bytes(s)
0x000000000F866A82 (0x0000000002A486D0 0x0000000000000001 0x0000000000000001 0x0000000000000000), Tcl_SubstObj() + 0x832 bytes(s)
0x000000000F7E1D94 (0x0000000002A486D0 0x00000000004949E0 0x0000000000000001 0x0000000000000001), Tcl_EvalEx() + 0x5A4 bytes(s)
0x000000000F84B660 (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000000000000), Tcl_FSEvalFileEx() + 0x250 bytes(s)
0x000007FEB2380383 (0x000007FEB9D51DF0 0x000000000293CF18 0x0000000002A486D0 0x00000C87A1B0B797)
0x000007FEB237F83C (0x000000000411E678 0x00000000003A0000 0x000000000411E678 0x00000000003AD500)
0x000007FEB99114E4 (0x0000000002A486D0 0x000000000411E678 0xFFFFFFFFFFFFFFFF 0x00000000Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)
Please check 'C:/########/########/###_hog/Release/_sds/vhls/hs_err_pid18800.log' for details
The hs_error_pid18800.log file contains:
# An unexpected error has occurred (EXCEPTION_ACCESS_VIOLATION)
Stack:
no stack trace available, please use hs_err_<pid>.dmp instead.
Many thanks,
 - Malcolm
Re: Vivado crash trying to accelerate HOGDescriptor with 16x16 cells
Hi @malcolmnixon
I am working on this issue.
Best Regards,
Nutan
Hi @malcolmnixon
HOGDescriptor supports 16x16 blocks only, it cannot be modified to use 32x32
Kindly refer to below document Page no. 156
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1233-xilinx-opencv-user-guide.pdf
Best Regards,
Nutan
