kardec
What's the difference between "paged" data movement and "contiguous" data movement?
heeran
Continuous means, buffers are placed into contiguous memory location in Physical DDR RAM. This is must needed requirement for Simple DMA or zero copy case.
Whereas Paged means, buffer is not allocated contiguous memory location. For this kind of buffer, zero copy and Simple DMA will not work. So for such case, SGDMA (scatter gather DMA) is needed for buffer transfer from/to DDR memory to/from accellerator.
-Heera
gill
Note that the content of the data motion report is the result of pragmas and static analysis.  As a result, if the static analysis cannot deduce whether or not something is paged/contiguous, it will present it as paged, as it must err on the side of caution.  If the memory is actually contiguous, it will not treat it as though it is paged.
In practical terms, "paged" memory requires that the memory be pinned prior to transfer, which is a very expensive procedure.  For the purposes of this topic, "paged" pretty much means "anything that was not allocated with sds_alloc".  As was previously mentioned, if sds_alloc is used, but the static analysis fails to deduce this, you'll end up with a paged-capable datamover [SG-DMA] at compile time, but you won't pay the pinning cost at run time.
