Where is the generated hardware design XPR?
In SDSoC (2016.1), after offloading a function to hardware and successfully compiling my project (ELF and BIN generated), I am examining the contents of the SDRelease/_sds/p0/ipi folder, but I do not see any *.log or *.xpr files to view the hardware implementation of my project.  I have specified the zed platform for my project and the only contents of the folder is zed.sdk/zed.hdf.  Is there a setting needed to generate the XPR file?
Re: Where is the generated hardware design XPR?
I figured it out.  It appears that the XPR was not generated because I had enabled the Estimate Performance option.
