Observer ang083
ZCU104-rv-ss-2017-4 Optical Flow Demo reVISION
My setup:
1) See3CAM_CU30_CHL_TC_BX USB Camera
2) HDMI Monitor
Optical flow demo
I downloaded the .zip file from https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841993/reVISION+Getting+Started+Guide+2017.4+rev2#reVISIONGettingStartedGuide2017.4rev2-8RuntheApplication
I followed the guide https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841993/reVISION+Getting+Started+Guide+2017.4+rev2#reVISIONGettingStartedGuide2017.4rev2-8RuntheApplication
I connected a HDMI cable to a monitor and See3CAM_CU30_CHL_TC_BX USB camera to ZCU104.
When I started Teraterm, the monitor gives a blue screen initially.
logfile:
root@zcu102_base_trd:/media/card# cp libopticalflow.so /usr/lib
root@zcu102_base_trd:/media/card# cp libgstsdxopticalflow.so /usr/lib/gstreamer-1.0
root@zcu102_base_trd:/media/card# cp libgstsdxbase.so /usr/lib/gstreamer-1.0
root@zcu102_base_trd:/media/card# cp libgstsdxallocator.so /usr/lib/gstreamer-1.0
root@zcu102_base_trd:/media/card# video_cmd -S
VIDEO SOURCE ID VIDEO DEVNODE
HDMI Input 0 /dev/video2
USB Webcam 1 /dev/video4
Virtual Video De 2 /dev/video0
root@zcu102_base_trd:/media/card# video_cmd -s 1 -i 1920x1080@UYVY -X
/dev/video4
root@zcu102_base_trd:/media/card# video_cmd -d 1 -o 1920x1080 &
[6] 2521
root@zcu102_base_trd:/media/card# ERROR: Query DV timings failed: Link has been severed
root@zcu102_base_trd:/media/card# gst-launch-1.0 v4l2src device=/dev/video4 io-mode=dmabuf! "video/x-raw, width=1920, height=1080, format=UYVY" ! sdxopticalflow filter-mode=1 ! queue ! kmssink driver-name=xilinx_drm plane-id=26 sync=false
(gst-launch-1.0:2561): GStreamer-CRITICAL **: gst_element_make_from_uri: assertion 'gst_uri_is_valid (uri)' failed
WARNING: erroneous pipeline: could not set property "io-mode" in element "v4l2src0" to "dmabuf!"
Anyone help? Thanks
Re: ZCU104-rv-ss-2017-4 Optical Flow Demo reVISION
Hi @ang083
*Below is not a solution, just a workaround*
Please try as mentioned below,
ssh into it.
1st shell:
video_cmd -d 1 -o 1920x1080-60Hz@AR24
Ignore the error message. As you don't need to exit the command, no reconfiguration of the sink takes place.
2nd shell:
gst-launch-1.0 v4l2src device=/dev/video4 io-mode=dmabuf ! "video/x-raw, width=1920, height=1080, format=UYVY" ! sdxopticalflow filter-mode=1 ! queue ! kmssink driver-name=xilinx_drm_mixer plane-id=28 sync=false
Best Regards,
Nutan
