about tcl.pre of bitstream setting
Hello everyone,
Can anyone tell me how to deselct the tcl in the tcl.pre of bitstream setting in the vivado 2015.4
when I made the path to blank and appled and reopen the dialog,the path was still existing.
Scholar pratham
Re: about tcl.pre of bitstream setting
@danpianji88 Just select and delete the path.
OR
Run this command
set_property STEPS.WRITE_BITSTREAM.TCL.PRE {} [get_runs impl_1]
-Pratham
Scholar pratham
OR
Run this command
-Pratham
Thanks for your replying.
But when I select and delete the path in the GUI,it doesn't work.
Can you tell me the deference between GUI and tcl command.
Thans a lot
Best wishes
Hi @danpianji88,
Deleting in the GUI mode also work.
After deleting in the GUI did you click on Apply?
After clicking on Apply after deleting the paths you should see below Tcl command:
Arpan
Hello
