eejlny
async and non-void return function
I am trying to use the async and wait #pragmas but the SDSOC 2016.1 tool reports that async cannot be used with non-void return function call.
So I removed the returns from the function call since I did not really need them.
But now the tool says that one of  ports being used in the function is axi_mm master and it needs a return parameter or at least and output scalar argument.
I tried to add a dummy output scalar to the function but the message remains.
The examples available from Xilinx so how to use the return which I cannot use to be able to use async/wait so I wonder if anyone has an example of how to use the output scalar instead of return.
sskalick
Hi eejlny,
I have tested the following code in both 2016.1 and 2016.2 SDSoC and it runs correctly on the ZC702 board (with add() function marked for hardware):
#include <stdio.h>
#include "sds_lib.h"
#pragma SDS data zero_copy(a);
void add(int *a, int b, int &c) {
	c = *a + b;
int main() {
	int *a, b=2, c=0;
	a = (int*)sds_alloc(sizeof(int));
	*a = 3;
#pragma SDS async(0)
	add(a,b,c);
#pragma SDS wait(0)
	printf("results is: %d\n\r",c);
	sds_free(a);
	return 0;
If you continue to have problems, please post some code snippets relevant to your problems.
Sam
eejlny
Thanks for the example. It works now.
I was not passing the scalar as a reference correctly but now I can use async with the void return.
Best Regards
