Visitor garion9013
c++ template supports on top module (function)
I've seen documents that HLS/SDSoC completely covers c++ template and its polymorphism
Is it still true with hardware function? (top module)
I failed to build test code below
#include <iostream>
using namespace std;
template<int size>
void top_accel(int a, int b){
  std::cout << a << std::endl;
  std::cout << b << std::endl;
int main(int argc, char** argv) {
  top_accel<1>(1,2);
If this is not the case, does Xilinx have any plans to support this?
or this kinds of usage is completely forbidden?
Teacher xilinxacct
Re: c++ template supports on top module (function)
@garion9013
Vivado HLS supports the use of templates in C++ for synthesis. BUT Vivado HLS does NOTsupport
templates for the top-level function.
Please mark as solution accepted to close the issue. Kudos also welcomed :-)
