Observer kemache
configure the PL clock in SDSOC 2018.2
I am a new in SDSoC developpment environment.
To implement my design I am using the zedboard. When building, my design doesn't met timing (at 100MHz) so I want to lower the frequency in SDSoC environment. Is it possible or I have necessary to create a new platform in Vivado with the frequency I desire then use it in SDSoC?
Thanks for your responses.
Re: configure the PL clock in SDSOC 2018.2
Hi @kemache
Slack is not less -> it is -0.278 (violation), So we need to fix this.
You cannot use skip timing xp parameter.
However you can try various options which I mentioned before (different directives)
If that doesn't help you might need to create the new platform  as you mentioned before.
Best Regards,
Nutan
Hi @kemache
I consider you have declared various clock IDs while creating a platform.
When you navigate to project.sdx, you can see below window,
However, before that I would like to tell you an option to optimize the timing.
Please navigate to C/C++ Build Settings->C/C++ Build-> Settings->SDS++ linker
add xp parameter in GUI as mentioned below.
sds++ -xp "vivado_prop:run.impl_1.{STEPS.PHYS_OPT_DESIGN.ARGS.MORE OPTIONS}={-directive Explore}" -xp "vivado_prop:run.impl_1.{STEPS.ROUTE_DESIGN.ARGS.MORE OPTIONS}={-directive Explore}"
If the slack is less, you can also add option to skip timing analysis,
-xp param:compiler.skipTimingCheckAndFrequencyScaling=1
Best Regards,
Nutan
Observer kemache
Hi @nutang
Thanks a lot for your response, it is very helpful.
Please I need your confirmation in what I have understood.
If I have an SDSoC application containing a hardware accelerator and I dont want to skip the timing analysis and I have choose a predefined hadware platform: zed with 4 clock IDs (100MHz, 142 MHz, 166MHz and 200MHz). For the hardware accelerator I use the clock ID of 100MHz. When building the application the timing is not met.
So if I want the hardware accelerator to work at the frequency of 70MHz I have inevitably to create a new platform in Vivado with a clock ID of 70MHz and then include it to SDSoC ?
Hi @kemache
If you do not want to skip the timing, I would suggest you to analyze the timing report first. Based on analysis you can try first option mentioned in my previous post, it will optimize the timing.
If explore directive doesn't help, you can analyse the timing report (techniques are documented below) and change the options and test.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug906-vivado-design-analysis.pdf
eg.
sds++ -xp "vivado_prop:run.impl_1.{STEPS.PHYS_OPT_DESIGN.ARGS.MORE OPTIONS}={-directive PerfOptimized_high}" -xp "vivado_prop:run.impl_1.{STEPS.ROUTE_DESIGN.ARGS.MORE OPTIONS}={-directive AreaOptimized_high}"
or
sds++ -xp "vivado_prop:run.impl_1.{STEPS.PHYS_OPT_DESIGN.ARGS.MORE OPTIONS}={-directive AreaOptimized_high}" -xp "vivado_prop:run.impl_1.{STEPS.ROUTE_DESIGN.ARGS.MORE OPTIONS}={-directive PerfOptimized_high}"
If suppose fanout is more, you can optimize fanout
vivado_prop:run.impl_1.{STEPS.PLACE_DESIGN.ARGS.MORE OPTIONS}={-fanout_opt}
You can post the timing report here if possible, I can help you.
Best Regards,
Nutan
Observer kemache
Hello @nutang
I tried the command in your first reply the slack is less but I still have the timing not met problem.
Thank you for your help.
The timming summary is attached in this message.
Hi @kemache
Best Regards,
Nutan
Observer kemache
Hello @nutang
Thanks a lot for your help.
I mean that the slack this time is less than without using the directive of timing optimization (it was -0.561).
I will try the other directives you mentioned.
Hi @kemache
Oh okay, got it.
Please let me know if any further help needed
Best Regards,
Nutan
Observer kemache
Hi @nutang
I will, thanks a lot.
Best Regards,
