Observer yxiaoa
fatal error: 'pthread.h' file not found
hi:
when i compile my code with sdsoc without hardware function, it works, i can get the elf file.
but, when i select a function to be hardware function, it will give me an error like"fatal error: 'pthread.h' file not found".
then i compare the log file, and get the difference:
log without hardware function:
C:\Users\Embed\workspace_parallel\dark\Debug>exit /b 0
Compiling C:/Users/Embed/workspace_parallel/dark/src/convolutional_layer.c
aarch64-linux-gnu-gcc -c {-IC:\Users\Embed\workspace_parallel\dark\src} -Wall -O0 -g -fmessage-length=0 -MMD -MP -D __SDSCC__ -MTC:/Users/Embed/workspace_parallel/dark/Debug/src/convolutional_layer.o -MFC:/Users/Embed/workspace_parallel/dark/Debug/src/convolutional_layer.d -MTC:/Users/Embed/workspace_parallel/dark/Debug/src/convolutional_layer.o     -I F:/Xilinx/SDx/2017.4/target/aarch64-linux/include  -D HLS_NO_XIL_FPO_LIB  -I F:/Xilinx/Vivado/2017.4/include C:/Users/Embed/workspace_parallel/dark/src/convolutional_layer.c -o src/convolutional_layer.o
log with hardware function
Performing accelerator source linting for forward_convolutional_layer
F:/Xilinx/SDx/2017.4/bin/sdslint -target cortex-a53 -func "forward_convolutional_layer" C:/Users/Embed/workspace_parallel/dark/src/convolutional_layer.c -- -c {-IC:\Users\Embed\workspace_parallel\dark\src} -Wall -g -fmessage-length=0 -MMD -MP -D __SDSCC__ -target aarch64-linux-gnu -mcpu=cortex-a53 -O0 -g -w    -I F:/Xilinx/SDx/2017.4/target/aarch64-linux/include  -D HLS_NO_XIL_FPO_LIB  -I F:/Xilinx/Vivado/2017.4/include   -IF:/Xilinx/SDK/2017.4/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include -IF:/Xilinx/SDK/2017.4/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include-fixed -IF:/Xilinx/SDK/2017.4/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -IF:/Xilinx/SDK/2017.4/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/libc/usr/include
aarch64-linux-gnu-gcc -c C:/Users/Embed/workspace_parallel/dark/Debug/_sds/swstubs/convolutional_layer.cpp -o C:/Users/Embed/workspace_parallel/dark/Debug/_sds/swstubs/convolutional_layer.o
i think the problem is in the second log: after  gcc -c, there is no inclued files.  if so, how could i include a driectory here?
thanks for anyone knows this.
Visitor sdroh1027
Re: fatal error: 'pthread.h' file not found
Project properties-> c / c ++ Build -> Settings -> SDS ++ Linker -> Libraries -> Libraries (-l) -> add "pthread"
Visitor zxbzsb
Hello there:
        I have encountered similar problems. How did you solve them?
