gprof profiling in SDSoC Emulation for ZCU102 board
I know how to use TCF profiling in Emulation mode in SDSoC for ZCU102 board. I want to use gprof profiling. I have seen the following posts and documents but none of them clearly mention how to use gprof in SDSoC Emulation.
https://forums.xilinx.com/t5/SDSoC-Environment-and-reVISION/Using-gprof-profiler-in-SDSOC/td-p/769074
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1235-sdsoc-optimization-guide.pdf
https://www.xilinx.com/html_docs/xilinx2016_2/SDK_Doc/index.html?q=/html_docs/xilinx2016_2/SDK_Doc/SDK_tasks/sdk_t_run_profiler.html
https://www.xilinx.com/html_docs/xilinx2016_2/SDK_Doc/index.html?q=/html_docs/xilinx2016_2/SDK_Doc/SDK_tasks/task_profilingtheapplication.html
I have tried by putting -pg flags in SDSCC and SDS++ compiler settings and selecting "Enable profiling". But after starting Emulation mode, in Debug perspective, I do not know how to start gprof profiling (as we do by clicking "Start" of TCF profiling). I have spent significant amount of time to sort it out.
I would truly appreciate if you please help me by providing step-by-step instruction of using gprof profiling in SDSoC Emulation for ZCU102 board.
Re: gprof profiling in SDSoC Emulation for ZCU102 board
I am still waiting for the reply. Any help is truly appreciated.
Cheers
Hi @immwn
Please have a look at the link below
https://www.xilinx.com/html_docs/xilinx2018_2/SDK_Doc/SDK_tasks/sdk_t_run_profiler.html
Best Regards,
Nutan
Hi @immwn
Is above link sufficient?
or you need any further assistance.
Best Regards,
Nutan
Hi @nutang
It did not work for me. I followed the following link to create HelloWorld application for Arm A53 of Zynq US+.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1209-embedded-design-tutorial.pdf
Then followed the link you shared to profile it. I know it is useless to profile a HelloWorld application. I am doing it for learning purpose. But it was not successful. I did not get the "Profile Option", so could not do steps 7-9 of https://www.xilinx.com/html_docs/xilinx2018_2/SDK_Doc/SDK_tasks/sdk_t_run_profiler.html
I am not sure what I should do for "Setting Up the Hardware for Profiling" for ZCU102 board.
When I do the step 1 of "Setting Up the Software for Profiling" it shows the following error.
For the step 2, "Enable profiling (-pg)" option was not there.
Using -pg flag in Miscellaneous also did not work.
How can I "Modify the software application code to enable interrupts"?
Can you please give me step-by-step instructions of using gprof in SDK or SDSoC?
Hi @immwn
In case of SDK, you can try same procedure with Dhrystone example.
hello world example gets executed fast.
gprof requires an application which can run for long time
Best Regards,
Nutan
Hi @nutang
As you can see the hello world application is not the issue. I cannot find profiling options in SDK 2018.3. Also i am not sure how i can prepare Zynq US+ zcu102 for gprof profiling.
Can you please share the steps of doing it?
Hi @immwn
I will create a video and share latest by tomorrow.
Best Regards,
Nutan
Hi @nutang
That would be very helpful.
Thanks a lot
I'm currently trying to the same thing, but ı found that link: https://www.xilinx.com/html_docs/xilinx2018_3/SDK_Doc/SDK_concepts/sdk_c_over_profile.html
which says "gprof is currently supported only for Cortex A9 & Microblaze processors" zcu102 has a53 cores in the PS side as ı know.
I'm using zcu104 which also has a53 cores.
How did you solve your problem?
Hi @nutang ,
I have been waiting for your video. Or can you please confirm if gprof profiling is not supported in A53 arm processor of ZCU102 board as @yasin.kagan mentioned?
Thanks as always
Hi @immwn
Yes, the document is correct.
I will confirm with concerned team and let you all know.
Best Regards,
Nutan
