Observer litaoqiyanjie
how to send the captured image to monitor by HDMI cable???
is there a simple method to send the captured image with videocapture(opencv) to the monitor in real-time?
something like follows:
capture image from camera ==>store to the sdcard(imwrite) ==> copy the image and display on the monitor
I am not sure if it is possible, or is there some reference code for image display?
Re: how to send the captured image to monitor by HDMI cable???
Here you will find a reVision Platform example for Zybo Z7-20 that uses HDMI interfaces for input and output : https://github.com/Digilent/reVISION-Zybo-Z7-20
And here is an example that displays on HDMI an image that is captured using a HDMI camera: https://github.com/Digilent/revision-samples/tree/master/live_IO/filter2d
Hope it helps,
Bogdan
