how to transform an SDK project to an SDSoC one
Hi all,
I have created an SDK application project targeting a custom hardware design made using Vivado, i wanted to accelerate some processing parts using SDSoC, so i have generated my custom SDSoC platform by following steps from this tutorial. but i'm not sure if i can copy/paste my code files from my SDK application project into the SDSoC application project, or i must do something else. any help would be appreciable.
Regards.
-Aziz-
Re: how to transform an SDK project to an SDSoC one
Hi @boularesaziz
Create an empty application project with the custom platform which you have created.
And you can right click on the project and navigate to import sources option.
When the import sources window pops up, give a proper path to the files and select appropriate files for import.
Once you have all the source files present, build a project and test before going for acceleration.
Best Regards,
Nutan
Hi @nutang
Thanks for your reply
I have done as you said but i got the following error:
fatal error: 'xspips.h' file not found
when i came back to my SDK project i found that file (xspips.h) in the following directory:
my_app/my_app_bsp/ps7_cortexa9_0/include
is there a method how to include ps driver files in my SDSoC project ?
