Observer anjali@8
reVISION stack
hello,
I was trying to execute an example from xfopencv design examples using reVISION platform zcu104. I am doing it through the terminal using the makefile. It works fine till the command comes "creating Vivado project and starting FPGA synthesis" after which it says synthesis is running and the PC gets hanged. After which I have to reboot my PC.
Alternatively I also tried doing it with sdx GUI and there also I am encountering the same problems. I tried executed some of the examples and in all of them I am facing this issue.
Please, help me resolve this issue.
****** vpl v2017.4 (64-bit)
  **** SW Build 2086221 on Fri Dec 15 20:54:30 MST 2017
    ** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
INFO: [VPL 60-895]    Target platform: /home/ignko-train/zcu104_rv_ss/zcu104_rv_ss.xpfm
INFO: [VPL 60-423]   Target device: zcu104_rv_ss
INFO: [VPL 60-251]   Hardware accelerator integration...
Creating Vivado project and starting FPGA synthesis.
[14:08:05] Synthesis is running.
[14:09:05] Synthesis is running.
[14:10:07] Synthesis is running.
[14:11:13] Synthesis is running.
[14:12:14] Synthesis is running.
[14:13:20] Synthesis is running.
Thank you!
Anjali
Re: reVISION stack
Can you step us through exactly what you are doing. I can try replicate your steps
Observer anjali@8
Re: reVISION stack
I downloaded the xfopencv design examples from github. I also downloaded the reVISION platform zcu104_rv_ss.
I selected an example accumulate that was given in the directory and from the terminal I executed the makefile to get the .elf file.
But whenever the command "Creating the vivado project and starting FPGA synthesis" is coming my PC is getting hanged and then it stops responding.
I have tried this with other examples also but same thing is happening.
Thank you
Anjali
Visitor vandenplas
Re: reVISION stack
I need help also as I cant get the revision stack to compile or run
I get a platform error ,,I really need some help
Visitor vandenplas
Re: reVISION stack
I get this message
WARNING: [DMAnalysis 83-1005] Invalid clock id 2 for platform revision
INFO: [DMAnalysis 83-4497] Analyzing callers to hardware accelerators...
INFO: [DMAnalysis 83-4444] Scheduling data transfer graph for partition 0
ERROR: [DMAnalysis 83-4503] No M_AXI_GP port found in the platform!
ERROR: [DMAnalysis 83-4445] Failed scheduling data transfer graph!
Observer anjali@8
Re: reVISION stack
Hey stephen,
Did you figured out the issue?
Thanks!
Re: reVISION stack
You need the license that comes with the ZCU104 board, otherwise Vivado will fail to generate the RTL (the ZCU104 board definition have new added IP licensed for the ZCU104 platform) and you'll have those errors as a result.
/* Don't forget to give kudos and/or accept as a solution */
Re: reVISION stack
Sounds like the PFM properties in your platform were not set correctly.
Can you post your PFM properties that you used with a screenshot of your BD in Vivado?
