daichong
reVision Getting Started failed
When I follow the steps in the Web page
http://www.wiki.xilinx.com/reVISION%20Getting%20Started%20Guide%202017.4
to compile the Optical Flow demo, the following error occurs, how can I solve it? My SDSOC is 2017.4, Vivado comes with the SDSOC installation. I had the same error when running this demo in Windows 10 and Linux .
INFO: [VPL 60-895]    Target platform: D:/SDx_project/zcu102_es2_rv_ss\zcu102_es2_rv_ss.xpfm
INFO: [VPL 60-423]   Target device: zcu102_es2_rv_ss
INFO: [VPL 60-251]   Hardware accelerator integration...
===>The following messages were generated while  creating FPGA bitstream. Log file:D:/SDx_project/of2/Release/_sds/p0/_vpl/ipiivado.log :
ERROR: [VPL 5-336] This command cannot be run, as the BD-design is locked. Locked reason(s):
* Block design contains locked IPs. Please run report_ip_status for more details and recommendations on how to fix this issue.
List of locked IPs:
zcu102_es2_rv_ss_mipi_csi2_rx_subsystem_0_0
zcu102_es2_rv_ss_v_mix_0_0
zcu102_es2_rv_ss_v_proc_ss_csc_0
zcu102_es2_rv_ss_v_proc_ss_scaler_1
zcu102_es2_rv_ss_v_proc_ss_scaler_0
wdlctc
I met the same problem as yours. May someone fix it.
diego73
The solution is to add the license that comes in your the ZCU102 platform, that license will unlock the usage of those IPs that are causing you a problem.
/* Don't forget to give kudos and/or accept as a solution */
zhanghao270
indeed, but how can I get  the license file from the Xilinx website?
I just could not find the entry.
