sdsoc _opencv error
hi,
this is sharmila am adding custom platform zybo_z7_20 successfully.
->and tri
regards ,
sharmila.
Re: sdsoc _opencv error
Hi @sharmilakotra123
Please have a look at the xfopencv
https://github.com/Xilinx/xfopencv
Document : https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1233-xilinx-opencv-user-guide.pdf
Best Regards,
Nutan
@sharmilakotra123
Are you trying to build canny example in this project?
Best Regards,
Nutan
hi yes but o got the same error for every project i.e;
16:37:38 **** Incremental Build of configuration Debug for project canny ****
make pre-build main-build
sdsoc_make_clean Debug
rm: cannot remove 'src/xf_canny_accel.o': No such file or directory
Building file: ../src/xf_canny_accel.cpp
Invoking: SDS++ Compiler
sds++ -Wall -O0 -g -I"../src" -c -fmessage-length=0 -MT"src/xf_canny_accel.o" -Wno-overloaded-virtual -Wno-unused-label -Wno-strict-overflow -Wno-uninitialized -Wno-unused-function -Wno-unused-variable -Wno-unknown-attributes -Wno-unused-local-typedefs -Wno-sign-compare -mstrict-align -hls-target 1 -MMD -MP -MF"src/xf_canny_accel.d" -MT"src/xf_canny_accel.o" -o "src/xf_canny_accel.o" "../src/xf_canny_accel.cpp" -sds-hw canny_accel xf_canny_accel.cpp  -clkid 0 -sds-end -sds-sys-config linux -sds-proc linux -sds-pf "/home/roash-sw-linux/Desktop/SdSoC-Zybo-z7-20/SDSoC-Zybo-Z7-20-master/sdsoc/zybo_z7_20/export/zybo_z7_20"
Processing -sds-hw block for canny_accel
Create data motion intermediate representation
clang: error: unknown argument: '-hls-target'
clang: error: no such file or directory: '/home/roash-sw-linux/Desktop/projects_web/canny/Debug/1'
ERROR: [SdsCompiler 83-5005] clang exited with non-zero code processing /home/roash-sw-linux/Desktop/projects_web/canny/Debug/1 /home/roash-sw-linux/Desktop/projects_web/canny/src/xf_canny_accel.cpp
sds++ log file saved as /home/roash-sw-linux/Desktop/projects_web/canny/Debug/_sds/reports/sds_xf_canny_accel.log
ERROR: [SdsCompiler 83-5004] Build failed
make: *** [src/xf_canny_accel.o] Error 1
src/subdir.mk:21: recipe for target 'src/xf_canny_accel.o' failed
16:37:41 Build Finished (took 3s.226ms)
can you please help me
regards
k sharmila
I suggest you to start a new fresh project by following below steps,
Important note : Export $SYSROOT before launching SDx
export SYSROOT=<platform>/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/
Launch SDx
You can download xfOpenCV directly from SDx GUI. To build a project using the example makefiles on the Linux platform.
1. From SDx IDE, click Xilinx and select SDx Libraries.
2. Click Download next to the Xilinx xfOpenCV Library.
xfopencv_lib_download.PNGThe library is downloaded into /Xilinx/SDx/<version>/xfopencv. After the library is downloaded, the entire  set of examples in the library are available in the list of templates while creating a new project.
3. To add a library to a project, from SDx IDE, click Xilinx and select SDx Libraries.
4. Select Xilinx xfOpenCV Library and click Add to project. The dropdown menu consists of options of which project the libraries need to be included to.
All the headers as part of the include/ folder in xfOpenCV library would be copied into the local project directory as /libs/xfopencv/include. All the settings required for the libraries to be run are also set when this action is completed.
5. Start creating a new SDx application project as per standard procedure, when you go to template window, you can see all example projects of xfopencv. Select Canny and click on Finish.
6. Navigate to C/C++ build settings->C/C++ Build-> Settings->SDS++ Linker-> Libraries
    Add ${SYSROOT}/usr/lib and ${SYSROOT}/lib
7. Navigate to C/C++ build settings->C/C++ Build-> Settings->SDS++ Linker->Miscellaneous->Linker Flags
Add below line before -sdcard ..src/data
--sysroot=${SYSROOT} -L=/lib -L=/usr/lib -Wl,-rpath-link=${SYSROOT}/lib,-rpath-link=${SYSROOT}/usr/lib
 8. Please navigate to C/C++ build settings -> C/C++ General->Paths and Symbols
In Includes tab, Under GNU C++, Add below include path,
<revision platform folder path>/zcu104-rv-ss-2018-2/petalinux/sdk/sysroots/aarch64-xilinx-linux/usr/include
Best Regards,
Nutan
hi,
am following above processor also i got the same error again , that canny example downloded but not showing in sdx libraries so i copied from my local xilink directory and runed .
-- but i have a doubt on i dont have aarch64-linux(petalinux path u mentionstioned but i have rootfs in where i can build the petalinux projects
i share my path just verify once...
->/home/roash-sw-linux/Desktop/SdSoC-Zybo-z7-20/SDSoC-Zybo-Z7-20-master/linux/zybo_z7_20/build/tmp/sysroots/plnx_arm/usr/include
but here i have all the libraries
Sorry, I did not get your below statement,
Also, please share screenshot of your SDS++ compiler options.
Best Regards,
Nutan
this is my compiler statemet
hi @sharmilakotra123
please remove "-hls-target 1" option and try
Best Regards,
Nutan
I tried with that also but when we build it automatically takes the target..here
Yes, just copy the whole content, paste it in some editor, remove -hls-target 1
and paste the content again at above location
Best Regards,
Nutan
yes i was doing that only when i remove hls_target 1 it showing the another below error.
--> am trying to clear the below error by adding xfopencv libraries to that same project it again comes with the hls_target 1 error like a loop
hi,
now i got the new error . i was clearing the above xf_common.h and target_hls 1
by removing hls and adding include path for xfopencv.
but now i got the new error,
K Sharmila
Okay, Actually the xfopencv is tested for zcu102/zcu104 revision platforms, zc706 platform.
It is not tested for zybo, so these errors are new for us too.
Best Regards,
Nutan
I will try to recreate the issue on my end, can you please try with SDSoC 2018.3?
Best Regards,
Nutan
ok i will try i want the installation guide and environment set up steps from starting to end like platform creation to project creation and build.
K Sharmila
->i was trying with Zc702,Zc701,Zc706 default platforms but i get the same below error.
->Actually we want to trying with zybo board we alredy have zybo board can you please check once with the zybo platform and tel to me
->if it works we want to plan all the project with zybo,i am trying to install 2018.3 can you please share the process to installation and environmental set up (with screecshots more benifited to me).
K Sharmila
Hi ,
actually in 2017.4 i was trying with zybo live i./o video i cleared all errors
but this time i dont know what error it is it simply says compiler termimated like this.
10:28:56 **** Incremental Build of configuration Debug for project sample_video ****
Building file: ../src/filter2d/filter2d_cv.cpp
sds++ -Wall -O0 -g -I"../src" -I"/home/roash-sw-linux/opt/Xilinx/SDx/xfopencv/include" -c -fmessage-length=0 -MT"src/filter2d/filter2d_cv.o" -Wno-overloaded-virtual -Wno-unused-label -Wno-strict-overflow -Wno-uninitialized -Wno-unused-function -Wno-unused-variable -Wno-unknown-attributes -Wno-unused-local-typedefs -MMD -MP -MF"src/filter2d/filter2d_cv.d" -MT"src/filter2d/filter2d_cv.o" -o "src/filter2d/filter2d_cv.o" "../src/filter2d/filter2d_cv.cpp" -sds-sys-config linux -sds-proc linux -sds-pf "/home/roash-sw-linux/Desktop/SdSoC-Zybo-z7-20/SDSoC-Zybo-Z7-20-master/sdsoc/zybo_z7_20/export/zybo_z7_20"
Compiling /home/roash-sw-linux/Desktop/new1/sample_video/src/filter2d/filter2d_cv.cpp
sds++ log file saved as /home/roash-sw-linux/Desktop/new1/sample_video/Debug/_sds/reports/sds_filter2d_cv.log
Finished building: ../src/filter2d/filter2d_cv.cpp
Building file: ../src/filter2d/filter2d_xf.cpp
sds++ -Wall -O0 -g -I"../src" -I"/home/roash-sw-linux/opt/Xilinx/SDx/xfopencv/include" -c -fmessage-length=0 -MT"src/filter2d/filter2d_xf.o" -Wno-overloaded-virtual -Wno-unused-label -Wno-strict-overflow -Wno-uninitialized -Wno-unused-function -Wno-unused-variable -Wno-unknown-attributes -Wno-unused-local-typedefs -MMD -MP -MF"src/filter2d/filter2d_xf.d" -MT"src/filter2d/filter2d_xf.o" -o "src/filter2d/filter2d_xf.o" "../src/filter2d/filter2d_xf.cpp" -sds-sys-config linux -sds-proc linux -sds-pf "/home/roash-sw-linux/Desktop/SdSoC-Zybo-z7-20/SDSoC-Zybo-Z7-20-master/sdsoc/zybo_z7_20/export/zybo_z7_20"
Compiling /home/roash-sw-linux/Desktop/new1/sample_video/src/filter2d/filter2d_xf.cpp
                 from /home/roash-sw-linux/Desktop/new1/sample_video/src/filter2d/filter2d_xf.h:13,
                 from /home/roash-sw-linux/Desktop/new1/sample_video/src/filter2d/filter2d_xf.cpp:42:
compilation terminated.
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'arm-linux-gnueabihf-g++ -c -I../src -I/home/roash-sw-linux/opt/Xilinx/SDx/xfopencv/include -Wall -O0 -g -fmessage-length=0 -Wno-overloaded-virtual -Wno-unused-label -Wno-strict-overflow -Wno-uninitialized -Wno-unused-function -Wno-unused-variable -Wno-unknown-attributes -Wno-unused-local-typedefs -MMD -MP -D __SDSCC__ -MT/home/roash-sw-linux/Desktop/new1/sample_video/Debug/src/filter2d/filter2d_xf.o -MF/home/roash-sw-linux/Desktop/new1/sample_video/Debug/src/filter2d/filter2d_xf.d -MT/home/roash-sw-linux/Desktop/new1/sample_video/Debug/src/filter2d/filter2d_xf.o     -I /home/roash-sw-linux/opt/Xilinx/SDx/2017.4/target/aarch32-linux/include  -D HLS_NO_XIL_FPO_LIB  -I /home/roash-sw-linux/opt/Xilinx/Vivado/2017.4/include /home/roash-sw-linux/Desktop/new1/sample_video/src/filter2d/filter2d_xf.cpp -o src/filter2d/filter2d_xf.o'
make: *** [src/filter2d/filter2d_xf.o] Error 1
sds++ log file saved as /home/roash-sw-linux/Desktop/new1/sample_video/Debug/_sds/reports/sds_filter2d_xf.log
src/filter2d/subdir.mk:21: recipe for target 'src/filter2d/filter2d_xf.o' failed
10:29:08 Build Finished (took 11s.685ms)
this was by build.can you please help me out
K Sharmila
am encouter with new error previous errors was gone like i changed to test platform for same project there only like zc702,701,zed,701 agin i came to zubo .
->previous errors was gone but these errors related to program ??
Can you please verify your SYSROOT.
Also, the error says redefinition with different types: you can also verify your include paths
Best Regards,
Nutan
this is my linker paths and i didt fing that sysroot where it is in gui.
Yes, then not setting SYSROOT is leading to all errors.
This is how we set for revision platform
  • Linux: export SYSROOT=<platform>/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/
https://github.com/Xilinx/reVISION-Getting-Started-Guide/blob/master/Docs/tool-flow-tutorials.md
Best Regards,
Nutan
Hi ,
i was doing that also and tried but it won't work .
Okay.
Try building canny example on command line.
Best Regards,
Nutan
can you please share the commands how to execute from starting i was trying with that also but i did't got the proper commands
Please have a look at the below docu,
Go to Page no.24 you can see commands for building a project using example makefiles on linux.
Best Regards,
Nutan
hi ,
i have stuck in a problem like ubuntu i was mounting the opartitions after that it automatically copy in Desktio (Document,Downloads, music etc.)
after if i deleted in desktop it will automaticcaly deleted in original location and showing below error.
K sharmila
hi i got the errors in this sdsoc revision platform haar face deduction can any one help me out.
presently i was able to build the opencv simple web dedution sdx using revision platorm.
but am getting error in cascade classifier showing error,
Hi am getting the below error for face detection cascade cassifier how to rectify it
