sdsoc with petalinux
I am new to SD_SOC but I have some experience with petalinux. I need to know whether it is possible to use image.ub and *.elf files that generate from sdsoc, with petalinux. Because I need to use USB camera and X11 forwarding through ethernet. I am using zedboard.
Re: sdsoc with petalinux
Hi @1ymw1
Okay. You can use the board bsp
Best Regards,
Nutan
Hi @1ymw1
You need to create a new platform
https://www.xilinx.com/html_docs/xilinx2018_2/sdsoc_doc/lpj1534452982777.html
Please refer below link for preparing the Image for the SDSoC Platform Utility
https://www.xilinx.com/html_docs/xilinx2018_2/sdsoc_doc/linux-boot-files-bks1504034371884.html?hl=petalinux
Best Regards,
Nutan
hey @nutang
Thanks, I will get back to you if I find any difficulty.
Hi @1ymw1
Any Update?
Best Regards,
Nutan
hi @nutang
I have a problem with software platform creation (https://www.xilinx.com/html_docs/xilinx2018_2/sdsoc_doc/linux-boot-files-bks1504034371884.html?hl=petalinux). If I want to create software platform using petalinux can I use the bsp file for that board or do I have to implement the hardware platform?
Hi @1ymw1
Are you using custom board or xilinx evaluation board?
Best Regards,
Nutan
hi @nutang
I am using ZED board and ultra96 board from avnet.
Hi @1ymw1
Best Regards,
Nutan
