Newbie humans
using xf::mat in custum hardware function
Hi guys,
I'm trying to make my custom hardware function through SDSOC revision platform.
I am using ZCU104 board and, I read image and try to find center of white parts of image after threshold.
The code to find center should use image data. So, I made xf::mat and used it to compare with value.
However, error message is occurred.
Please let me know why it is not supported..
Here is my code.
void findcenter_accel(xf::Mat<XF_8UC1, HEIGHT, WIDTH, NPIX> &_src)
#pragma SDS data access_pattern("_src.data":SEQUENTIAL)
#pragma SDS data copy("_src.data"[0:"_src.size"])
#pragma SDS data mem_attribute("_src_mat.data":NON_CACHEABLE|PHYSICAL_CONTIGUOUS)
unsigned short width = _src.cols;
unsigned short height = _src.rows;
int center_calx = 0, center_caly = 0;
int count = 0;
cols:
for (int i = 0; i < width ; i++)
rows:
for (int j = 0; j < height ; j++)
if (_src.data[i*width +j] == 255)
center_calx = center_calx + j;
center_caly = center_caly + i;
count++;
Error Message:
Description Resource Path Location Type
DMAnalysis 83-4432: An unsupported inferred interface type (ap_memory) was detected
Re: using xf::mat in custum hardware function
Hi @humans
below pragmas are located at wrong place.These pragmas must be specified immediately preceding a function declaration or immediately
preceding another #pragma SDS bound to the function declaration. I also suggest you to check the order.
Please refer below guide.
https://www.xilinx.com/content/dam/xilinx/support/documentation/sw_manuals/xilinx2018_2/ug1253-sdx-pragma-reference.pdf
Best Regards,
Nutan
@humans Write the pragmas immediately preceding the function declaration, like this:
void findcenter_accel(xf::Mat<XF_8UC1, HEIGHT, WIDTH, NPIX> &_src);
