denghaibo
why sdsoc reports "faided DSA integrity check: digest mismatch"?
Dear,
I used lab1.tcl and created a vivado project, it genarated a DSA file. Then I use the sdsoc created a custom platform. But when I created an sdsoc arraypartition example and building it ,the console reports "faided DSA integrity check: digest mismatch",why?
thanks!
skalicky
Can you provide more step-by-step details of how you created your vivado project? Did you use the same version of Vivado that gets installed with SDSoC? Which version of SDSoC/Vivado are you using?
Sam
khareashish_trimble
I get the same warning with 2017.4 zcu102 revision stack platform. Even though it shows up as a critical warning the project builds fine and generates the SD card image.
Can someone explain the reason for this Warning
me too!
stephenm
Can you post the steps you used here. Can you post the PFM TCL file used here so we can have a better idea what flow was taken prior to this error?
1ymw1
hi @stephenm
I am having the exact same issue and I have attached a link to the my whole vivado project. can you please tell me what the problem is?
https://www.dropbox.com/s/9ss3p7cy0uh4b2e/ultra.zip?dl=0
