xf :: bitwise_not build error occurs.
Hi.
I used the bitwise_not function instead of the xf::filter2D H/W function in the filter2d example.
If you build the bitwise_not function by selecting Toggle H / W, the following error occurs.
INFO: [DMAnalysis 83-4494] Analyzing hardware accelerators...
ERROR: [DMAnalysis 83-4432] Interface type of port p_src_data_V_q0 of accelerator w0_xf_bitwise_not not supported!
Data motion generation exited with return code 1
- errors detected
sds++ log file saved as /data1/hccho/sdx/zcu102_rv_ss/sw/sysroot/filter2d/Release/_sds/reports/sds.log
ERROR: [SdsCompiler 83-5004] Build failed
source:
void filter2d_sds(unsigned short *frm_data_in, unsigned short *frm_data_out,
		  int height, int width, const coeff_t coeff, void *priv)
	struct filter2d_data *f2d = (struct filter2d_data *) priv;
	int pcnt = height*width;
	// split the 16b YUYV... input data into separate 8b YYYY... and 8b UVUV...
	read_f2d_input(frm_data_in, *f2d->inLuma, *f2d->inoutUV, f2d->in_fourcc, pcnt);
	// this is the xfopencv version of filter2D, found in imgproc/xf_custom_convolution.hpp
	//xf::filter2D<XF_BORDER_CONSTANT, KSIZE, KSIZE, XF_8UC1, XF_8UC1, F2D_HEIGHT, F2D_WIDTH, XF_NPPC1>
	//	(*f2d->inLuma, *f2d->outLuma, (short int *) coeff, 0);
        xf::bitwise_not<XF_8UC1, F2D_HEIGHT, F2D_WIDTH, XF_NPPC1>(*f2d->inLuma, *f2d->outLuma);
	// combine separate 8b YYYY... and 8b UVUV... data into 16b YUYV... output data
	write_f2d_output(*f2d->outLuma, *f2d->inoutUV, frm_data_out, f2d->out_fourcc, pcnt);
project:
Attach the sds.log file.
thanks.
Re: xf :: bitwise_not build error occurs.
Sdsoc does not support ap_memory but your argument "src" acctually is ! You can change it by pragma SDS data.
